It is currently Sat Jul 26, 2025 10:25 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Sun Nov 20, 2016 8:10 pm
phillb wrote:
bluehishouse wrote:
That is a long way forward! I was way off. Old holes are going to stick out badly... Do any other styles fit where the old wide holes are?
I don't think you've shown us where the old holes are?
From the photos, I don't think the mirror is too far forward. Most factory/dealer-fitted mirrors were meant for that position. If you end up with 2 drilled holes they can be filled with small rubber plugs/grommets until you can weld them up and repaint the door.
And when locating a door mirror I have always tried to put it about the same distance from my eyes as the centre inside mirror is so that you can quickly scan from one to the other without refocusing.
PostPosted: Mon Nov 21, 2016 8:46 pm
MinisPlus
I used these on my car. It does take a bit of patience to locate them perfectly but well worth it.
I have not had any problems in the 7 years they have been on and with a little polish still look like new.
They are the best mirrors I have ever had on a mini and compared to some out there give a great rear view.
I used the supplied plastic plinth and it's been fine. I'll see if I can find a pic of them fitted for you.
Ben.
How can it be rusty when it's covered in so much oil?
PostPosted: Tue Nov 22, 2016 6:06 am
My driver's door had a bunch of holes which the painter forgot to fill.
So I screwed a S/S screw into the spare front one. It doesn't look too bad. I can't fully open the wing window, but as doing this drags the rubber out I don't bother anyway.
After my mirror fell off the pathetic standard plastic base, I bought a replacement mirror, and the metal plinth kit CZH3521 from Karcraft. No problems since.
PostPosted: Tue Nov 22, 2016 6:50 am
There are a few holes around it. Im trying to fix one i have off the 78 but the plinth might be tge go, the plastic looks crap
Sent from my SM-G900I using Tapatalk
PostPosted: Fri Dec 09, 2016 9:58 pm
What Doc said, if you don't use the plinth the mirror will fall off. Learnt from experience.
Dalmeny
PostPosted: Sat Dec 10, 2016 8:28 am
Especially if you "over tighten" the horizontal fixing bolt ! :oops:
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
Users browsing this forum: TartanRed and 85 guests
