It is currently Mon Jun 23, 2025 11:07 pm
Post new topic Reply to topic  [ 221 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15  Next
PostPosted: Tue Nov 08, 2016 12:19 pm
Excellent. Can't wait to see everyone's cars. Should be a good day.
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
PostPosted: Wed Nov 09, 2016 8:38 am
Photos of the finished project.
1961 Morris mini
PostPosted: Sun Nov 13, 2016 6:16 pm
It's was good to meet you today and see your masterpiece in the flesh so to speak. You should be very proud this is an excellent conversion and better in real life that the photos.
Rob
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Fri Nov 18, 2016 10:51 pm
Cheers thanks Rob. It was good to chat to yourself and other like minded mini people.
1961 Morris mini
PostPosted: Fri Nov 25, 2016 4:55 am
After a few days of driving I realised that this was required to get the perfect clutch throw. Works a treat.
1961 Morris mini
PostPosted: Fri Nov 25, 2016 8:38 am
Die Die Die!!
I want one
PostPosted: Fri Nov 25, 2016 2:07 pm
nice simple solution, though a bigger, maybe plastic foot might be a good idea - the bolt will probably thump a hole in your carpet
PostPosted: Fri Nov 25, 2016 4:23 pm
Yeh I thought of that but I don't need to push it hard to the floor so it should be ok. Good advice though.
1961 Morris mini
PostPosted: Fri Nov 25, 2016 7:11 pm
How do you find the weight of the clutch pedal?
PostPosted: Sat Nov 26, 2016 7:15 am
when you're fanging through the hills and the red mist descends, you're not going to be gentle with it, you'll be punching it to the floor and back up as quick as you can...
PostPosted: Sat Nov 26, 2016 7:37 am
True. Fanging around is pretty common now with the new engine.
1961 Morris mini
PostPosted: Sat Nov 26, 2016 10:03 am
I bet...
PostPosted: Wed Feb 08, 2017 1:09 pm
Driving around has been fun but as we all know, it is a project car and there is always something we can do to it.
I wanted wider wheels to fill out the wheel arches but not as wide as the usual minilites or superlites. I also wanted something different.
I found these and have been impressed.
Ultralite Enki 13x7 but with an offset of +2 so they don't stick out as far as the usual Ultralites. No spaces required either.
1961 Morris mini
PostPosted: Wed Feb 08, 2017 2:19 pm
Die Die Die!!
Very nice, where did you find them?
PostPosted: Wed Feb 08, 2017 7:32 pm
Mini sport UK
1961 Morris mini
Users browsing this forum: No registered users and 27 guests
