It is currently Sat Jul 26, 2025 10:37 pm
PostPosted: Fri Nov 25, 2016 6:39 pm
Hi all
Just a quickie, i have a stock 1100 with a 1 1/4 su, can i put a 1 1/2 on there with extractors and bigger exhaust. just that one person is telling me yes and a friend is saying 1 1/2 is too big. I was sure some 1100s came out with them.
Anyways the only reason i thought i would is i have it on the inlet manifold, and the 1 1/4 one on the car will have to cut the manifold to put the extractors on.
thanks :) julie
PostPosted: Fri Nov 25, 2016 6:50 pm
Theres minis with them standard but you'll still have to cut the inlet from the exhaust, sssssimple. :-)
PostPosted: Fri Nov 25, 2016 6:57 pm
I have an inch and a half on an inlet manifold sitting there so it would bolt on. If i reuse the original i have to cut
Sent from my SM-G930F using Tapatalk
PostPosted: Fri Nov 25, 2016 7:26 pm
1 1/2 will work fine on an 1100.
PostPosted: Fri Nov 25, 2016 7:42 pm
You can get a nice kit like these from the UK with all the bits you need. The needle and tuning will need checking to make sure it's running ok.
http://www.minispares.com/product/Class ... 0to%20shop
PostPosted: Fri Nov 25, 2016 8:33 pm
The 1.5 carb and its stock manifold is worth probably 3HP or so.
In UK it was used on all the automatics including 850, to offset power loss through the torque converter.
PostPosted: Fri Nov 25, 2016 10:03 pm
Running a 1.5, K&N filter, 3-1 extractors and RC40 muffler over here on my K, no dramas
PostPosted: Fri Nov 25, 2016 11:01 pm
http://www.sw-em.com/su_carbs.htm
handy chart. as long as your 1100 is putting out more than 45 bhp byte less than about 80 then you're fine. Don't trust the chart though, just a guide.
Users browsing this forum: Bill B and 94 guests
