It is currently Sat Jul 26, 2025 10:35 am
PostPosted: Fri Nov 18, 2016 9:33 pm
Anyone have a picture of a tex side mirror install? I got one but just can't seem to get it to sit where I can see it.. Anyone have pics?
Sent from my SM-G900I using Tapatalk
PostPosted: Sat Nov 19, 2016 8:15 am
The blue one appears to be high, but the mirror can be swung out of the way to fully open the q/v window, and then re-positioned.
The other position is equally as good.
HTH
PostPosted: Sat Nov 19, 2016 10:37 am
That isn't what mine looks like. Its a flat rectangular mirror.
PostPosted: Sat Nov 19, 2016 10:40 am
PostPosted: Sat Nov 19, 2016 10:49 am
You didn't say that. Sorry I tried to help you.
PostPosted: Sat Nov 19, 2016 10:53 am
Oh no sorry mate I was confusing myself with what mine is called. I appreciate the help!
PostPosted: Sat Nov 19, 2016 1:03 pm
The mounting will be basically the same as the bullet mirror. a plastic base attaches to the door, then the mirror mounts to the base.
you just have to get the masking tape out and play around with positioning first.
PostPosted: Sat Nov 19, 2016 1:49 pm
I think my difficulty is this specific mirror =/ it doesn't have the movement to sit where I need it. Fighting the urge to throw it..
PostPosted: Sat Nov 19, 2016 2:55 pm
You can buy a Tex metal plinth that lifts the mirror up.
Beware the standard plastic base you have, they can warp in the summer heat then the mirror falls off. Like mine did. I will put a pic of mirror + plinth up when I find it.
Karcraft stocks the metal plinth now.
PostPosted: Sat Nov 19, 2016 4:59 pm
Here you go. There is a sweet spot when you fit these. Needs to be far enough forward so as not to interfere with the quarter vent opening all the way.
PostPosted: Sat Nov 19, 2016 6:38 pm
Ideal is to get someone to help by holding the mirror while u sit in the drivers seat. Check u can still open the quarter window. You can always have the mirror lower an further back along the door. Remember the closer the mirror is to you the more you will see in it.
PostPosted: Sun Nov 20, 2016 8:07 am
That is a long way forward! I was way off. Old holes are going to stick out badly... Do any other styles fit where the old wide holes are?
PostPosted: Sun Nov 20, 2016 11:02 am
I have tried 2 sets of these...... both are now in rubbish. The plastic base is junk, it should be atleast diecast or ally.
PostPosted: Sun Nov 20, 2016 11:49 am
Yeah I'm not thrilled. You can't alter the angle either. Return methinks. Thanks for the rplies
PostPosted: Sun Nov 20, 2016 12:17 pm
I don't think you've shown us where the old holes are?
