It is currently Tue Jun 24, 2025 10:23 am
 Post subject: Upright handbrake
PostPosted: Wed Nov 09, 2016 7:39 pm
Does anyone know of an upright MECHANICAL handbrake available for a Mini?
Thanks
 Post subject: Re: Upright handbrake
PostPosted: Thu Nov 10, 2016 1:57 pm
never seen one, not even sure of a convenient place to put it where you could get a pivot point high enough without going through the floor - wouldn't be an issue in a moke?
going for a bench seat conversion??
PostPosted: Thu Nov 10, 2016 9:17 pm
does it need to ratchet? if not then just cut the existing one and re-send at the correct angle.
PostPosted: Fri Nov 11, 2016 7:20 am
Thanks guys
The problem is that I can't reach the handbrake with a full harness seat belt fitted. And it is a Moke with a low seating position. It does need a ratchet. Upright hydraulic handbrakes are available but I need a mechanical one.
Thanks
PostPosted: Sun Nov 13, 2016 4:47 pm
Presumably we're talking 'khanas ...?? Just weld a vertical section on top of the existing lever. Choose the length of the addition to give the mechanical advantage you require...
Maybe replace the locking mechanism with a fly-off catch. Just remember to release the handbrake before belting up :)
Cheers, Ian
PostPosted: Sun Nov 13, 2016 4:56 pm
Brings back memories of modifying the standard handbrake in my rally Mini to fly-off. I think it just reversing the pawl isn't it?
Apologies for detour in this thread. :wink:
PostPosted: Sun Nov 13, 2016 5:03 pm
Thanks Ian
At present I have a two handled 'fly off' style handbrake but would like to be able to release it with the harness fitted.
Thanks for the input
PostPosted: Mon Nov 14, 2016 7:18 am
Yes, sort of. You weld a bit to the other end of pawl to attach the rod to so it's spring loaded off not on.
I modded one 10 years ago, it not on my car yet as I've not got a round tuit. ;)
PostPosted: Mon Nov 14, 2016 1:49 pm
Fly off handbrakes are excellent, I have one. Great anti theft device, no one can work it out until you show them. Ooops, revealed one of my theft prevention measures...!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Nov 16, 2016 3:22 pm
just out of curiosity, is that a restriction in your club/class ?
normally the restriction is that the handbrake must work evenly on both wheels, but the actuation method is free
PostPosted: Wed Nov 16, 2016 9:09 pm
No it is not a regulation for competition but I don't have the space for an hydraulic handbrake and I don't want to re engineer the car for its use (for rego )
PostPosted: Wed Nov 16, 2016 9:13 pm
fair enough...
I've been trying to remember what car I've driven that had a vertical handbrake. It had a squeeze type handle near the gearstick...
edit: no, wasn't like a falcon, it was a handle that poked straight up from the floor - it might have been a split screen Kombi
PostPosted: Wed Nov 16, 2016 10:19 pm
I think the splittys came straight up out of the floor but had a button on the top like a normal horizontal lever.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Thu Nov 17, 2016 5:02 pm
I have tried a 37 Fiat Topolino but the ratchet is below the floor and I am very tight in that area with the gearshift (rod type ) and exhaust.
PostPosted: Fri Nov 18, 2016 7:31 pm
mount it above the floor in a little box above the tunnel?
invert it and make it a push away instead of pull towards?
