It is currently Sat Jul 26, 2025 9:58 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Tue Nov 15, 2016 9:04 pm
I've never seen a stock crank pulley bolt too long, indeed some are really too short in the thread. But flywheel bolts, definitely yes. Worth checking.
PostPosted: Tue Nov 15, 2016 9:40 pm
I've just searched the website which I should have done in the beginning. All the info I needed was already there. Sorry about that and thank you for all the replies. I will try the "remove the engine mounts and lift the engine" method. God know's how I did it in the past, I forget.
I'm not actually sure I've had to do it before with the engine in the car..
My Mini's (think I'm up to number 6) never really gave me any trouble. I'm still thankful it happened today and not tomorrow because I was off on a trip....
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Nov 16, 2016 8:31 am
How old is your bottom radiator hose , bypass hose ?, now would be a good time to change them if they have too much age on them :wink: .
PostPosted: Wed Nov 16, 2016 9:34 am
I don't have one of those 'orrible bypass hoses fitted and the bottom hose is newish and looks fine.
Thanks
Michael
67 Deluxe
Dry suspension
PostPosted: Wed Nov 16, 2016 10:42 am
If you have a `orrible' concertina bypass hose (a refugee from Morris Minor parts bin), bin it and fit 1/2" heater hose, which is what the Cooper S had.
Or use 1/2" Pirtek hydraulic hose like I do. Good for 500psi.
PostPosted: Wed Nov 16, 2016 10:49 am
i don't have a bypass at all. I've never had any problems and it seems to be a useful/ convenient modification to have?
67 Deluxe
Dry suspension
PostPosted: Wed Nov 16, 2016 10:53 am
Sorry, I misread your post. Yes, no prob running without a bypass, most people put a 3mm hole in the thermostat if they do.
