It is currently Sat Jul 26, 2025 10:28 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Temp gauge issue?
PostPosted: Mon Nov 14, 2016 7:36 pm
OOP's
yep 'c' not 'f'
my bad , sorry
Mark
PostPosted: Tue Nov 15, 2016 3:50 pm
The Mini King
I may well get shot down with this, however it has been my experience
that if you change the GTR104 temp sender unit to a GTR101 unit
the temp indicated on the gauge tends to be more accurate.
PostPosted: Tue Nov 15, 2016 5:18 pm
Its treason to shoot a King !
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
PostPosted: Tue Nov 15, 2016 5:24 pm
some food for thought.. I'm going to try it..
http://spriteparts.com.au/tech/overheating.html
66 MK 1 Cooper S
64 Grp N Cooper S
64 Grp N Cooper S (ex Bob Asher)
64 GRP N Cooper S (ex Fred Burley)
PostPosted: Tue Nov 15, 2016 6:36 pm
The Mini King
I am sure the Doc could better advise you on this, however, it is my understanding that the cooling problems with the Mini east west mounted engine, are different to those of the north south mounted engines.
The second point I would make is avoid using the tin impeller type water pump at all times.
PostPosted: Wed Nov 16, 2016 7:35 am
Your Gracious Majesty...if I may?
Moss 760-180 - Unipart GTR104 - Smiths SNB102 or TT3802/00
Moss 131-565 - Unipart GTR101 - Smiths SNB103 or TT3803/00
101 reads "N" at 180 deg and the 104 or Moss #760-180 reads halfway between "N" and "H
In Pomgolia:
GTR102 TRANSMITTER, water temperature 1961-64.
GTR104 TRANSMITTER, water temperature 1964-69.
GTR101 TRANSMITTER, water temperature 1969-85.
Try this at home...
https://www.youtube.com/watch?v=wFHWpgHMAvY
PostPosted: Wed Nov 16, 2016 8:03 am
The Mini King
In Pomgolia:
Try this at home...
I Agree with your comments, I have found that the GTR104 that are avail today
just do not always perform as they should
PostPosted: Thu Nov 17, 2016 9:37 pm
One time I had the sender out of the head. Stuck it in kettle and boiled the water with a digital thermometer in the water . I seem to remember mine was 76 like docs. I have a wombat stabiliser too. Mine is the type with a red hot area. 100deg was right at the start of the part marked red.
PostPosted: Sun Nov 20, 2016 6:34 pm
Seems very appropriate that The Mini King is at Windsor 8)
Users browsing this forum: Bing [Bot] and 102 guests
