It is currently Sat Jul 26, 2025 10:26 pm
PostPosted: Mon Nov 14, 2016 2:09 am
Milatsmadmini
Anyone have a really easy to read/understand wiring diagram on how to install? I low key am horrible at wiring, something that says, take the green wire from EDIS and add to such and such would be ideal....
Ta :D
PostPosted: Mon Nov 14, 2016 3:30 pm
its pretty easy using the installation guide just follow the numbers. had a quick look at mine on the edis plug
no.1 - green/white is the pip signal to mega jolt (shielded cable)
no.2 - red / yellow is the saw signal to mega jolt (shielded cable)
no.5 - green to - on crank sensor (shielded cable)
no.6 - blue to + on crank sensor (shielded cable)
no.7 - cable shields + ground
no.8 - +12v on edis
no.9 - Green/black to ground
no.10 - green/yellow to no.1 brown/geen on coil pack
no.12 - brown/red to no.3 brown/blue on coil pack
no.2 on coil pack purple/black needs a +12v
the mega jolt also needs a +12v and ground
make sure you use shielded cable for the signal wires to the crank sensor and the mega jolt and earth the sheath and all +12v are switched via ignition.
PostPosted: Mon Nov 14, 2016 11:27 pm
Milatsmadmini
thanks amigo
PostPosted: Tue Nov 15, 2016 10:06 am
no.8 - +12v on edis
noice... I added this to the how-to
Users browsing this forum: Bing [Bot] and 101 guests
