It is currently Sun Jun 22, 2025 10:39 am
 Post subject: Re: Annoying miss
PostPosted: Wed Nov 09, 2016 6:38 pm
The Tacho was actually correct the revs were bouncing around :(
So drive it to work this morning and (touching wood) the issue seems to have gone
maybe the non square round module was causing the problem
1968 Morris Mini Cooper S
PostPosted: Thu Nov 10, 2016 5:31 pm
Well day 2 and 4 runs down the freeway and the problem is gone
Mini's turning drivers into mechanics
PostPosted: Thu Nov 10, 2016 8:11 pm
Sounds like it just needed a decent run to clear its throat :)
PostPosted: Fri Nov 11, 2016 5:36 am
She gets run down the freeway everyday [THUMBS UP SIGN]
As for clearing it out. I have removed the accelerator peddle and replaced it with an on/off switch
