It is currently Mon Jun 23, 2025 5:09 am
 Post subject: Annoying miss
PostPosted: Tue Nov 08, 2016 12:56 pm
Here is a video constant throttle https://vimeo.com/190660137
It's driving me nuts
New leads in plugs stealth box inc distributor and coil
1968 Morris Mini Cooper S
PostPosted: Tue Nov 08, 2016 1:28 pm
More video this time the timing it seems to be jumping around
Note I have set the black box to 0 no advance
 Post subject: Re: Annoying miss
PostPosted: Tue Nov 08, 2016 3:56 pm
Distributor body well clamped?
PostPosted: Tue Nov 08, 2016 4:02 pm
Double check all spade connections are tight and they are well attached to the wire.
Check wired up dissy weights have not come loose.
Spark plug bodies porcelain and inside outside of dissy cap squeaky clean and dry.
PostPosted: Tue Nov 08, 2016 4:03 pm
This time with video https://vimeo.com/190672686
PostPosted: Tue Nov 08, 2016 4:04 pm
Hmmm I haven't checked the weights I'll do that
PostPosted: Tue Nov 08, 2016 5:40 pm
I got rid of all spade connectors on the coil, replaced With ring terminals. Loose or frayed connections are a perennial source of misfires.
PostPosted: Tue Nov 08, 2016 5:53 pm
Sounds rough as guts...you could throw another set of plugs at it...
PostPosted: Tue Nov 08, 2016 6:27 pm
Ring connectors are a good idea
Here are the plugs one is not like the otherImage
PostPosted: Tue Nov 08, 2016 9:51 pm
also the timing seems to jump around a fair amount
PostPosted: Wed Nov 09, 2016 6:36 am
PostPosted: Wed Nov 09, 2016 6:55 am
I noticed this too, with a timing belt and Pulsar electronic dizzy, my timing was steady as a rock all the way from idle.
With the black box on the dialback timing light `shows' it moving around.
However......
1. It idles much better.
2. It goes harder.
3. Fuel economy is much improved.
So, I'm not sure the timing `moving around' is real, both the black box and dialback timing light use similar spark delay technology. Electronics of both may be interacting.
PostPosted: Wed Nov 09, 2016 7:26 am
I pulled the dizzy out yesterday and noticed the module did not have the same gap all the way around to the rotor button so I adjusted that.
The video is a bit hard to hear it is actually idling nicely and goes hard and economy is now awesome. Those plugs I through in just to check it wasn't the plugs I am running iridium plugs in it. By the way as a side note the iridium plugs make a noticeable difference to power.
I'll keep hunting thanks for the help might see if I can find a pulsar dizzy or I might go dizzy free if it drives me nuts enough
PostPosted: Wed Nov 09, 2016 7:58 am
and sending a confused waveform to the Tacho...
PostPosted: Wed Nov 09, 2016 8:17 am
With a black box fitted, Pulsar dizzy works no better or worse than a Lucas with electronic module. I'm currently using a 43D with powerspark module.
