It is currently Sat Jul 26, 2025 10:41 pm
PostPosted: Tue Jun 09, 2015 5:11 pm
simon k wrote:
just make sure you have the correct #18, otherwise all hell will break loose
Nah, it's #15 rubber grommet that needs to be factory correct if you are looking for a concours winner. :roll:
PostPosted: Mon Nov 07, 2016 8:54 pm
Does anyone have a measurement for where the bolt (#8) for the bottom of the strap should be on the floor? When I mock mine up it seems like it should be inside the sealed area of the beaver panel? Doesn't seem right as I was expecting it to be further inboard where it was accessible from underneath?
PostPosted: Tue Nov 08, 2016 7:25 pm
Online
My 4/66 S does not have a captive nut below the floor like later Ss - just a hole, but the bolt is just accessible for a nut/washer from under the beaver panel and is very close to the panel that seals the corner of the beaver.
I can give you measurements if I can work out any reference points. It's the same location as the later ones with captive nut.
Bill
PostPosted: Tue Nov 08, 2016 10:00 pm
Bill
Well I bit the bullet and drilled today. The hole is referenced from the left tank and is as close as I could get it to the panel on the beaver. It still doesn't seem to be far enough in when I have the tank fitted from what i have seen from other pictures of twin tank boots but I can live with it.
PostPosted: Wed Nov 09, 2016 1:42 pm
Online
Bill
I spent about 3 weeks trying to get the RH tank to sit with a decent amount of filler neck sticking out of the body like LH. The original hole in the floor I found is slightly too far towards the centre of my car causing the strap to not let the tank sit towards the outside. I elongated the hole on the strap end to get more movement.
Your photo seems to show a reasonable amount of filler neck, even though your tank is slightly towards the middle of the car compared to where mine ended up.
Users browsing this forum: Bill B, Bing [Bot] and 94 guests
