It is currently Sat Jul 26, 2025 10:36 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Sat Oct 29, 2016 11:56 am
simon k wrote:
78Clubbie wrote:
Is it a rod change ? Make sure the plate under the selector is around/installed the right way
nup
mc4me wrote:
watched the linkages while someone went through the gears, the left lever at the back of the box goes to first ok, when moved to second it only goes up a touch
The description above suggests it is a remote box not a rod change.
PostPosted: Sat Oct 29, 2016 4:19 pm
simon k wrote:
mc4me wrote:
Have removed the remote extension housing
mc4me wrote:
Yes it is a rod change.
I'm confused...
Sorry Simon, my double dutch jibbering, it definitely is a remote gearbox. It is a 4 speed syncro box converted to take the original remote, has been this way for 30 or so years. And now has pot joints to boot.
PostPosted: Sat Oct 29, 2016 5:56 pm
peterb wrote:
Looks like it could need surgery. Somethings not right inside. :-(
There's a few things that could cause it ....inside. Have you tried selecting gears directly using shaft sticking out box?
Yep peterb, removed the linkages down behind the motor, uses a socket and long bar, can select all gears bar second, like hitting a brick wall, something inside the box is stopping it from going in. Anyway, out she comes.
PostPosted: Sat Oct 29, 2016 6:02 pm
mini053 wrote:
Is it a 3 synchro or 4 synchro box? If 3 synchro, if 1st gear has been assembled out of phase on the 1st & 2nd hub the interlock plunger will prevent second gear engaging. I know this from bitter experience!
It's a 4 speed syncro box with remote extension mini053. I'm just going to pull it out, seperate from the engine, have a squiz in case it's something obvious, and send it back to be fixed.
PostPosted: Sat Oct 29, 2016 8:19 pm
We'll all stay tuned. Looking forward to the next episode.
PostPosted: Sat Oct 29, 2016 8:31 pm
Just a thought if it was a 3 synchro....hope you get it sorted mate.
PostPosted: Sat Nov 05, 2016 6:32 pm
Pulled the motor out, split the box, saw the problem straight away. Took it back to my man on Friday, stripped, appears the 1st/2nd selector fork thingy was a late model one. When selecting 2nd, the fork was hitting against the gearbox casing. Changed out, reassembled everything today, repainted and ready to install tomorrow. The guy was pissed off with himself, but hey, crap happens sometimes, we'll get over it.
Thanks to everyone for their inputs and information. Much appreciated.
PostPosted: Sat Nov 05, 2016 7:41 pm
bugger, but alls well that ends well.... I bet he'll do a gear change check next time
PostPosted: Sun Nov 06, 2016 10:36 am
He can't cop all the blame though. I shouldn't have had to, but maybe I should have checked as well. Learnings for other people here. Check, check then check again. With a bit of luck I'll be going for a spin around my paddock and up in to the court as well this arvo. A nice policeman lives there, maybe I'll pick him up for a burn !
PostPosted: Sun Nov 06, 2016 12:32 pm
I like to do everything myself - which also means I like to fiddle with things - so I'm pretty sure that if I'd had a gearbox rebuilt by someone I'd be playing with it to see how it worked before I put it a motor on it...
but I don't like building things for other people, because if I stuff something up then I've let them down when they trusted me to do a good job, which really sucks - so I know how he feels
PostPosted: Sun Nov 06, 2016 2:19 pm
The UK are suppling 3 synchro 1-2 selector forks as suitable for 4 synchro remote boxes. The 4 synchro forks were shorter and weaker.
Sometimes these fit OK (my car), other times (eg a recent box I did) they need trimming to fit. The rear wall of the gearbox case varies in position.
I guess doing this saves the manufacturer keeping a part.
Just check before putting the cluster gear, diff pinion and diff in!!! :)
PostPosted: Sun Nov 06, 2016 7:00 pm
Yep, I feel the same Simon, I like doing my own stuff where I can. The guy is a top bloke, do anything for you and yes, I should have checked. I'll still be dealing with him though. No harm done, just time, I'll miss the mini show next weekend though, but should make it to the big day out in Dec.
PostPosted: Mon Nov 07, 2016 2:01 pm
when I used to swing spanners for a living on mini cog boxes etc I checked all my own work before any bills were paid..............
....you just lost him his insurance bonus!
997
PostPosted: Fri Nov 11, 2016 9:56 pm
Went for a run today, all gears work fine. Now sorthing out a few tething problems then she'll be on the road.
Users browsing this forum: Bill B and 94 guests
