It is currently Sat Jul 26, 2025 10:42 pm
PostPosted: Fri Nov 04, 2016 12:46 pm
Hi All,
As the exchange rate is looking good at the moment I'm considering ordering a 7.5" disc brake kit. The question is, what extra parts would be worth getting at the same time? Some 5/8" rear wheel cylinders would be on the list, is there anything else that needs to be replaced or is worth doing while I'm pulling it all apart to fit?
E.g. doesn't look like brake hoses are included, is it worth getting uprated brake pads, dust shields, will master cylinder be OK, etc.
Thanks, Tim
PostPosted: Fri Nov 04, 2016 12:53 pm
Just me, but I'd leave the dust shields off altogether. Also get some extra copper washers.
I purchased a kit last year. I also bought the 5/8" rear cylinders. The kit was missing the grease nipples for the hubs. The brake hoses and copper washers. Get some extra shims for the ball joints. The standard pads were ok for daily driving but you may want green stuffs or similar for hard driving.
PostPosted: Fri Nov 04, 2016 12:58 pm
Yes lose the dust shield tinware it just restricts cooling and collects gravel.
PostPosted: Fri Nov 04, 2016 1:54 pm
agree with gtogreen get the 5/8 cylinders, hoses, washers and shims.
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Fri Nov 04, 2016 2:00 pm
Throw in a set of Greenstuff pads as well, you wont buy cheaper in Aus
PostPosted: Fri Nov 04, 2016 2:08 pm
+1 for ball joint shims and brake hoses (they are different lengths to drums)
1967 Morris Mini Deluxe
PostPosted: Fri Nov 04, 2016 4:07 pm
Definitely extra balljoint shims ( 2 lots of P/N 2A4242
BALL JOINT EXTRA SHIM KIT (6 SHIMS), as well as the front brake hoses as the drum ones are longer than the disc ones and can foul the axles. I got braided hoses for all 4 corners.
C-AJJ4030 BRAKE HOSE BRAIDED FRONT PAIR ONLY
C-AJJ4031 BRAKE HOSE BRAIDED REAR PAIR ONLY
From MiniSpares UK.
PostPosted: Fri Nov 04, 2016 9:03 pm
Do you wide drums on the rear?
The discs give a wider track on the front compared to standard drums.
PostPosted: Fri Nov 04, 2016 9:40 pm
Do you need to keep it under $1000?
PostPosted: Sat Nov 05, 2016 8:00 pm
A dial gauge, a large drill bit or grinding cone, a long steel pipe that will go over your breaker bar, a tin of Timkin bearing grease
Dial gauge to check that flange is seated correctly onto disc (had this problem today, 11 thou disc wobble)
Large drill bit or grinding cone to put a chamfer on drive flanges as the new ones don't have any at all where the wheel stud holes are, which causes above issue
Long steel pipe to do the hub nut up beyond 150ft/lbs to next available hole
Timkin bearing grease obviously for bearings
PostPosted: Mon Nov 07, 2016 3:25 pm
Thanks for all the feedback! Ideally I'd keep it under $1000 to avoid any extra tax etc...
I've currently got flat drums and Contessas and I'd prefer not to grind down new calipers to make them fit or put flares on.. So I'd need to add on another set of wheels, new rear drums and wheel studs too. It all spirals out of control rather quickly doesn't it!
PostPosted: Mon Nov 07, 2016 3:47 pm
My Contessas go over my calipers after a small amount of grinding down (almost just polishing). You might consider trying your Contessas over the calipers before forking out for a new set of wheels. Then, if that worked, you could "just" fork out for rear drums and wheel studs. Either way, you're going to be doing two orders if you want to keep both below the evil threshold.
PostPosted: Mon Nov 07, 2016 4:01 pm
Even if my Contessas did fit over the calipers they'd stick out too far as they are the drum offset ones.
Would standard 850 steel wheels fit over Cooper S 7.5" brakes?
PostPosted: Mon Nov 07, 2016 4:24 pm
Aaahh!
Can't say about the steelies. Never tried that. I have MiniLites over my drum brakes in my other Mini (but they are Moke ones with the 3/4" step). These though are the same Minilites as are fitted to another Mini in the family with disc brakes.
Users browsing this forum: Bing [Bot] and 91 guests
