It is currently Sun Jul 27, 2025 7:34 am
PostPosted: Mon Sep 12, 2016 6:26 pm
I have movement in the drivers side output shaft this is allowing the rubber uni joint to rub on the engine housing
Would this slop be coming from the #4 bronze bush or is it from the #7 side bearing
what is the best way to tackle this?
thanks
PostPosted: Mon Sep 12, 2016 6:47 pm
the correct answer is "it would be coming from the #4 bronze bush or the #7 side bearing, or maybe something else"
either way, the best way to tackle it is to pull the motor out and look...
PostPosted: Mon Sep 12, 2016 6:58 pm
Can you tackle it from underneath with engine in?
PostPosted: Mon Sep 12, 2016 7:26 pm
You can but try, but the diff cover has to come off.
PostPosted: Mon Sep 12, 2016 7:33 pm
And if you don't use the same shims and gasket thickness it will muck up the bearing preload. New gaskets are 3x thicker than originals.
These bushes are more than 0.007" undersized in the bore. They need to be bored to fit the drive yoke after press fitting to the cover.
Engine out job, IMO.
PostPosted: Tue Sep 13, 2016 5:51 am
thanks guys
PostPosted: Mon Oct 31, 2016 12:32 pm
the drivers side yoke had some movement. i removed the flange bronze bush to yoke is a reasonable fit (without measuring)
but there is side movement in the gear drive shaft. now i am assuming there shouldn't be movement.
maybe a bearing gone. looks like diff rebuild
Any advice from guru's out there much appreciated
video below
PostPosted: Mon Oct 31, 2016 12:51 pm
There is always some shaft side movement with the side cover off, the length of the shaft exaggerates it.
re the rubber coupling rubbing, this is often due to the U-bolts being overtightened. That swells the rubber outwards. And modern coupling rubber is inferior to that used originally.
A good mod is to toss both rubber couplings and fit QL5000 universal joints. Last `forever' compared to rubber ones. ;)
PostPosted: Mon Oct 31, 2016 2:12 pm
Thanks doc. I did replace the rubber unis with nylon one and still had the noise. that is why i am digging a little deeper :?
PostPosted: Mon Oct 31, 2016 4:34 pm
I suspect the noise is internal, could be a bearing as suggested, or a chipped tooth on the crown wheel.
PostPosted: Mon Oct 31, 2016 9:25 pm
Just finished rebuilding my diff (literally this evening) found that the fibre washer as well as the no.4 bush was resulting in the lateral movement of the output shaft. As stated previously there will be some movement but heapes better now.
PostPosted: Tue Nov 01, 2016 8:00 am
thanks guys
Users browsing this forum: acarseldine and 115 guests
