It is currently Thu Jul 24, 2025 8:39 am
 Post subject: Re: 1965 seat belts
PostPosted: Wed Oct 12, 2016 4:02 pm
BBY755 wrote:
Here are pics of my belts.....
Thanks for that. They are the same as Bubbaclubys.
PostPosted: Wed Oct 12, 2016 6:42 pm
Thankyou also for the images. GTO Green beat me to the request :)
My 66S had part of its belt there branded Star and Now I know exactly what they look like.
PostPosted: Wed Oct 12, 2016 6:48 pm
A bit of elbow grease and yours will look the same. :D
PostPosted: Fri Oct 14, 2016 1:36 pm
gtogreen1969 wrote:
There are plenty of period correct styles available for sale in the UK and USA (Lift up and push button release). I doubt if they would be able to pass an inspection as they need the AS label. You may just have to use the modern belts sold by mini shops.
Would this mean the inertia reel ones from minispares U.K. Would also have issues getting through rego, given they wouldn't specifically meet an AS?
If the car is pre a certain year, do the AS requirements even apply in the same way?
Mini-less ... for now
PostPosted: Fri Oct 14, 2016 1:45 pm
Minisport in Adelaide has AS standard ones.
http://minisport.com.au/seat-belts-and-seat-belt-parts
PostPosted: Fri Oct 14, 2016 2:05 pm
As far as i am aware you either run with no belts on an early car that had none fitted or you need to fit belts that are approved AS.
PostPosted: Fri Oct 14, 2016 2:06 pm
Thanks makes sense. Couldn't find anything on search then realised I needed to type seat belts as two words rather than one and a whole stream of informative threads came up
PostPosted: Sat Oct 15, 2016 11:59 am
The grey 2 inch belts fitted as standard to the 1965 & 1966 Cooper S had the black plastic lift up buckle as pictured earlier in this thread. The brand was "Cooldrive", & having them fitted to my car to this day, I can testify they are not particularly good, as the buckles sometimes self open!
The webbing can still be found on e bay occasionally, but not the hardware, so the best bet is to get hold of a set from a Morris 1100 wreck.
Not sure what was fitted to the Deluxe, but a couple of other Adelaidians may be able to help, - Phil & Barry?
