Corrected an error I'd made above...
If the blower fan is working on the lowest speed, then it is earthing via the resistor pack (C425-4 is connected to C425-1) and then via C275-12 on the AC Switch pack. This indicates these wires are all connected to earth the blower motor, and as the clutch is energised it must be also connected through to pin C172-2 on the relay module.
When the blower speed is on any of the other settings, the blower fan must earth through either the resistor pack (via pins C275-2 or C275-3) for the mid speeds or via pin C275-7 on the AC Switch pack on the highest blower speed. Also, while on any of these blower speed settings, the relay module will earth via pin C275-1 on the resistor pack, through either 1, 2, or 3 resistors depending on which blower speed is selected. i.e. on the highest blower speed the relay module earth is via pin C425-4 on the resistor module, to pin C275-7 on the AC Switch pack (to the blower speed switch).
So, if the blower fan is operating in all positions including the lowest with no 'dead spot' anywhere, all the resistors must be fine and it must be a high resistance joint somewhere. Probably between C425-1 and that SJ27 connection on the diagram I'd guess.
The resistor pack is often placed on the side of an air duct with the resistors poking on the inside to cool them in the air-stream.
_________________ Don't listen to what I am saying... just understand what I mean.
