It is currently Sun Jul 27, 2025 9:01 pm
PostPosted: Tue Oct 04, 2016 12:03 pm
Lillee wrote:
It's not the top of a valve is it???
only if its a valve off a matchbox car...
PostPosted: Tue Oct 04, 2016 12:33 pm
Right, can't tell the scale of it!
Now that you mention it yeah it's really small :lol:
Lillee - 1969 Morris Mini K
PostPosted: Tue Oct 04, 2016 1:14 pm
Actwelly...the magnet would be similar OD to the collet end of a valve...so the item could be part of a valve (but unlikely!)
PostPosted: Tue Oct 04, 2016 3:43 pm
850 valves would be pretty small? (assuming you have an 850 with a magic wand)
PostPosted: Tue Oct 04, 2016 5:25 pm
too small for the end of a mini valve, i`d say it`s a rivet out of first motion saft bearing cage,
just a guess tho
PostPosted: Tue Oct 04, 2016 5:26 pm
thanks for the comments. the size is 3.25mm a few more picks ..
PostPosted: Tue Oct 04, 2016 6:01 pm
just a guess tho
http://www.minispares.com/product/Classic/AAU8424.aspx
PostPosted: Tue Oct 04, 2016 6:11 pm
As mentioned earlier I'd guess that is the end of one of the links in the timing chain.
Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
PostPosted: Wed Oct 05, 2016 6:22 am
Could even be a foreign body that's found its way in, maybe in dirty oil funnel,or while engines was apart a some time.
Does look a lot like rivot head but.
PostPosted: Wed Oct 05, 2016 7:49 am
kiwiinwgtn wrote:
just a guess tho
No, not that one, that is the 1st motion shaft pilot bearing.
This one
http://www.minispares.com/product/Classic/Gearbox/Replacement_Parts/Bearings/2A3709.aspx?150701&ReturnUrl=/product/Classic/Gearbox/Replacement_Parts/Bearings/ADU7619.aspx|Back%20to
Or even the diff bearing
http://www.minispares.com/product/Class ... o%20search
PostPosted: Wed Oct 05, 2016 9:00 am
sitnlo62 wrote:
kiwiinwgtn wrote:
just a guess tho
This one
Yeah that's probably what it is
PostPosted: Wed Oct 05, 2016 2:45 pm
Brad
I'd agree with that.
Users browsing this forum: No registered users and 72 guests
