It is currently Sun Jul 27, 2025 4:08 pm
 Post subject: Front lower arm pins
PostPosted: Mon Oct 03, 2016 6:07 pm
Different diameter ?
Silver is original
Gold is new replacement
As the original doesnt fit the new bushes I wonder if they've changed the sizing or have I got the wrong one ? :/
Simonw
Brisbane QLD
1st car - 1964 Mini Panelvan 850
Previous - 1978 Leyland LS 1275 Gold
- 1969 Mini K
 Post subject: Re: Front lower arm pins
PostPosted: Mon Oct 03, 2016 7:27 pm
Check that it,s not a steel sleeve over original pin
16v, twin cam, 'a'series, cooper S replica,3x dcoe webers,Around 200 HP and heaps of torque
PostPosted: Mon Oct 03, 2016 7:40 pm
Looks like the inner steel sleeves from the old bushes have stayed on the pins. Plenty of heat (gas or oxy torch) and vise grips should get them off.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Mon Oct 03, 2016 7:42 pm
Brilliant ! Didn't think of that , thanks ! mat and snurk
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Mon Oct 03, 2016 10:41 pm
And Matt I knows because we got the sleeves off our lower pins like that on Friday :)
Don't listen to what I am saying... just understand what I mean.
PostPosted: Tue Oct 04, 2016 11:02 am
Why doesn't the gold pin have a flange welded to the end? Without it, the nut would only be holding the pin at one end?!
PostPosted: Tue Oct 04, 2016 11:22 am
Thats all the nut does even with the flange there.
Theres very little load on the nut, the big flange is completely not necessary.
