It is currently Sun Jul 27, 2025 7:47 am
PostPosted: Fri Sep 30, 2016 10:09 pm
As per the title......I am getting a rattle/vibration noise from the RH front when I accelerate then brake lightly.
When I apply more pressure the noise disappears.
I have the Minisport 8.4" slotted vented discs and 4 piston calipers.
I have a feeling the outer pad is rattling. It is loose when the car is at a standstill without the brakes applied.
All bolts are on the calipers and suspension are tight.
Has anyone else had this noise? If so what did you do to stop it?
Any help will be appreciated.
Cheers.
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
PostPosted: Fri Sep 30, 2016 10:12 pm
If that top photo is the finished install you're missing the spring/anti rattle plate that goes between pads and circlips.
If you cant get one to fit, just get some anti-rattle stuff that looks like double sided tape foe between the pistons and pads.
PostPosted: Fri Sep 30, 2016 10:41 pm
When I bought my greenstuff pads recently it came with some thick duct tape like material that you stick to the back of the pad and trim as needed. Works a treat although I didn't have anything on my black stuffs and they were fine?
PostPosted: Fri Sep 30, 2016 10:58 pm
how loose is loose? have you checked the runout on the rotor?
PostPosted: Sat Oct 01, 2016 4:38 am
There is no pulsating or feeling of warped discs so I don't think it is runout. I can get the noise doing less than 15kms when coming to a stop and It sounds like a vibration. At first I thought it was my plastic wheel arch liners vibrating or even the front grille. I removed these but it still made the sound. It kind of has that tin/metal sound to the vibration.
1961 Morris mini
PostPosted: Sat Oct 01, 2016 11:42 am
I have a pair of the anti rattle thingys in melb if you want to try them, I can access them sunday in Airport West
PostPosted: Sat Oct 01, 2016 2:53 pm
Do they suit the mini sport calipers? I have the original Rover ones but they don't fit the Minisport calipers. Thi split pins are further apart
1961 Morris mini
PostPosted: Sat Oct 01, 2016 4:23 pm
HERE is the 7.5 inch version - note the anti rattle plates shown in the bottoms image.
They could be compatible - shoot minisport.com.au or mini sport.com an email for the proper gear
PostPosted: Sat Oct 01, 2016 6:31 pm
mine are the same as the rover ones .....sorry
PostPosted: Sat Oct 01, 2016 7:53 pm
thanks Ben. I'll contact them on Monday.
1961 Morris mini
PostPosted: Sat Oct 01, 2016 7:54 pm
Thanks for the offer.
1961 Morris mini
PostPosted: Mon Oct 03, 2016 3:58 pm
Mine were noisy too. It's the split pin at the front and the pads moving slightly. Noise goes away when the pads have pressure on them. It's just how those brakes are. Nothing I tried fixed it.
PostPosted: Mon Oct 03, 2016 4:08 pm
Those Pads are the same as the Metro pads. you can see where the brake pad wear switch wires have been cut off. Metro 4 Pots have that necessary clip you are missing. You can see the correct clips in this link. http://www.minimania.com/part/C-AJJ4029 ... ersion-Kit
"Let us remove your "SHORTS"
PostPosted: Mon Oct 03, 2016 8:38 pm
I am in Adelaide later this week and will see f Minisport have them. I fitted the adhesive pads but it didn't fix the vibration/rattle.
1961 Morris mini
PostPosted: Tue Oct 04, 2016 8:07 am
Hmm, I have never noticed mine. Mind you I may now seeing as I can hear things that aren't the rattle of the horn button now that I replaced the stalk. I don't appear to have the 'spacer' in mind either. apologies for the bad angle, only photo I have with me.
Nick
