It is currently Sun Jul 27, 2025 11:24 pm
 Post subject: Starting issue
PostPosted: Sun Sep 25, 2016 5:59 pm
Hi all recently just got my mini going and painted.Been a few weeks in the process of putting it back together, but I went to start it today and not go. It's got 12.4 volts at the battery. Same amount of power at the starter soloniod. But don't have any spark. Running an Aldony dizzy. Is the battery to low in charge? It keeps winding over but no fire. Getting fuel into Webber.
 Post subject: Re: Starting issue
PostPosted: Sun Sep 25, 2016 7:55 pm
Whack a jump pack on it. If it fires, the battery will be buggered. Cheapest place to begin
Sent from my SM-G900I using Tapatalk
PostPosted: Sun Sep 25, 2016 8:20 pm
The battery has been on charge all day. It just winds and winds. Stuck a screw driver in one of the plugs to the head but no spark. Coil is about a month old so is the dizzy
PostPosted: Sun Sep 25, 2016 10:41 pm
Check that you have power to the coil.
Are the points opening and closing.
I know it's basic but ......
PostPosted: Mon Sep 26, 2016 6:02 am
How do you check for power to the coil? It's an electric dizzy
PostPosted: Mon Sep 26, 2016 7:06 pm
Googled how to test a coil have power on both sides. I'm wondering if the modual in the dizzy is blown again.
PostPosted: Tue Sep 27, 2016 5:15 am
What Coil are you using? Has it fired up and ran at all since you put it together?
"Let us remove your "SHORTS"
PostPosted: Tue Sep 27, 2016 7:09 am
Do you have a points dizzy you can throw in it , process of elimination .
