It is currently Sun Jul 27, 2025 8:13 pm
PostPosted: Wed Sep 21, 2016 5:07 pm
I'm Interested to know what is the standard clearance and what everyone's clearance actually is.
Roadworthy in VIC says 100mm at lowest point but I can't see too many minis being that high.
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
PostPosted: Wed Sep 21, 2016 5:33 pm
My clubby had about 2 fingers between the tyre and guard and was 110mm from the sump and 95mm from the ehxaust.
PostPosted: Wed Sep 21, 2016 6:36 pm
6 5/32 inches ground clearence is stated in a manual I have but pretty sure the exhaust would be the lowest point. probs going to raise mine for it's rwc on saturday :shock:
PostPosted: Wed Sep 21, 2016 7:44 pm
What you need to worry about is the lower, front fins on the sump...100mm is probably OK but they are still very vulnerable :!: :D
PostPosted: Wed Sep 21, 2016 8:12 pm
if it's less than 10cm then it's unroadworthy - I've been done for having my exhaust too low.
The cop got out a breath tester straw and waved it around under the car. It touched at the exhaust so I got a canary and $160 fine
The law was 6", but they reduced it to 4" when Minis were released in 1960
PostPosted: Wed Sep 21, 2016 8:24 pm
Wow mine was sat on the ground when i Bought it the underneath looks like the moon the amount of dents it has. i can see every speed hump it ever went over. So i raised it.
its now more comfortable and goes over speed humps
1968 Morris Mini Cooper S
PostPosted: Thu Sep 22, 2016 8:25 am
Mine is 135mm to the sump
PostPosted: Thu Sep 22, 2016 9:59 am
There are alot of irate "drifters" on some of the facebook groups, when the cops set up check stations. They generally go around with a 100mm Ball on a stick, shove it under in a few places and see if it hits anything.
Nick
PostPosted: Thu Sep 22, 2016 5:51 pm
I thought mini's were allowed by law to be 90mm or something like that :?:
But your 6" to 4" sounds a bit more correct.
PostPosted: Thu Sep 22, 2016 6:14 pm
Girlfriends Jetta would be lucky to clear 60mm... Makes for some interesting times :lol:
PostPosted: Thu Sep 22, 2016 6:54 pm
100mm is the minimum height in Victoria. Some roadworthy checking stations have a ball on a stick to check underneath. If you hoon around and give the cops the shits, they will find something, and I don't blame them. Hoons and dickheads ruin it for everyone.
PostPosted: Fri Sep 23, 2016 8:31 pm
ADR 43 says 100mm. After converting mine to a B16 which is slightly heavier it will be tough to get it that high even if it is just for the roadworthy.
1961 Morris mini
PostPosted: Sat Sep 24, 2016 10:16 am
My B16 mini is 100mm clear of the ground to everything when the seam under the door is at 245mm from ground......
After a roady I'll probably lower it about 20mm again if I can - I'm not sure how the suspension will take the weight so it may need to sit at that height anyway.
PostPosted: Sat Sep 24, 2016 12:24 pm
Is that ADR apply to all minis or just 71 onwards?
PostPosted: Sat Sep 24, 2016 12:29 pm
Cars manufactured pre-ADR are picked up by the Vehicle Standards Rules, which specify the same 100mmm anyway... so it applies to all cars.
Don't listen to what I am saying... just understand what I mean.
Users browsing this forum: Bing [Bot], Phil 850 and 86 guests
