It is currently Sun Jun 22, 2025 9:26 pm
 Post subject: max RPM
PostPosted: Mon Sep 19, 2016 9:47 pm
Can anyone tell me what the max RPM in general should be for a 1275 seems like a mild cam standard head bored to 1310 should be
I engine seems to be happy to rev and 6000 RPM doesn't seem to be an issue.
what did they rev to out of the box?
1968 Morris Mini Cooper S
 Post subject: Re: max RPM
PostPosted: Mon Sep 19, 2016 9:52 pm
I used to rev my Cooper S to 35mph in first, 56mph in second and 77mph in third. Just as the speedo says.
No idea what rpms but. No tacho
PostPosted: Mon Sep 19, 2016 10:00 pm
I have the opposite problem MPH is not accurate and I have a smiths RPM gauge so it's closer to accurate
PostPosted: Mon Sep 19, 2016 10:04 pm
My last mini was a worked 1330 with Cooper S internals and it went to 6500rpm easily but ran out of grunt if you took it to 7000rpm.
PostPosted: Mon Sep 19, 2016 10:15 pm
cool I have the RPM limiter set to 6500 so I might have it about right
PostPosted: Mon Sep 19, 2016 10:55 pm
HP peak was at 5,800rpm, so 6500 is OK. HP is diving by 7000.
PostPosted: Mon Sep 19, 2016 11:03 pm
viewtopic.php?f=2&t=91129
PostPosted: Mon Sep 19, 2016 11:17 pm
My motor is a near stock mk1 1275
30th over bore and an old 266 cam grind
it made max torque at 5000 and max horse power at 6000
I have my red line set at 5500 for day to day driving
not that I don't take it to 6500 or more every now and again :shock:
PostPosted: Tue Sep 20, 2016 6:40 am
Thanks, i'll have to get mine on a Dyno and set it correctly but his has provided me with a good round about number
PostPosted: Tue Sep 20, 2016 7:08 am
I wouldn't be using six and half grand on a round about... :arrow:
(better to be near peak torque...)
PostPosted: Tue Sep 20, 2016 7:32 am
It's just used for the Rev limiter on my dizzy
PostPosted: Tue Sep 20, 2016 7:39 am
My black box rev limiter is set at 7500, because my HP peaks at 7000 or so. Not that I go there often... :wink:
PostPosted: Tue Sep 20, 2016 4:38 pm
Just had a play with my black box hmmmm and now set the max rpm to 6500 I checked and had it at 6000 by accident also made a couple of other changes. Think I found a few Horses
