It is currently Sun Jul 27, 2025 11:09 pm
 Post subject: what type of cam ?
PostPosted: Mon Sep 12, 2016 1:22 pm
I have an old cam that has two rings around it and when the lobes are measured with a vernier the small part of the lobe is 1.088 and the large angle of the lobe is 1.350 ?
any ideas as to what this is ?
Did i tell you that all my minis are 850's ?
 Post subject: Re: what type of cam ?
PostPosted: Mon Sep 12, 2016 2:00 pm
those measurements on their own probably don't mean much without angles, ramps, durations
the rings are one clue but I don't know what to
how wide are the lobes? there are 3/8" and 1/2" versions being small and big bore respectively
PostPosted: Tue Sep 13, 2016 9:45 am
If it's pin drive with 3/8" lobe width it'll be a 1098 cam.
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Mon Sep 26, 2016 8:12 pm
It is a pin drive 3/8" lobe width
I guess it should be the similar to the old cam but with slightly more lift which should be fine for the stock rebuild.
PostPosted: Tue Sep 27, 2016 12:40 pm
The 1098 cam has additional exhaust duration (22 degrees) and valve lift (0.033").
Rod.
Users browsing this forum: Barkfast, Bing [Bot] and 90 guests
