It is currently Tue Jul 29, 2025 11:50 pm
 Post subject: Tyre pressures
PostPosted: Sun Sep 11, 2016 12:37 pm
My Scientific Publications manual states 24psi front and 22psi rear.
What is recommended for A008's on 10" rims.
Phil
 Post subject: Re: Tyre pressures
PostPosted: Sun Sep 11, 2016 12:43 pm
I used to run 30 at front 28 at back
PostPosted: Sun Sep 11, 2016 3:39 pm
Just pumped them up to your pressures, soooooooo much better :D
PostPosted: Mon Sep 12, 2016 9:34 am
If i have a load in the car ie:( Rylstone) Run , i run 32 all round , normal running = 32 F , 30 R .
PostPosted: Mon Sep 12, 2016 10:46 am
Oh my, I have been waay off with my pressures. Ive been having 36 psi on all tyers :(New to minis, only owned my Leyland for under a year so shall keep this handy.
For my own learning, why do we have different pressures for the front and rear? I also drive a golf GTI which is front wheel drive and the factory recommends same pressure on all wheels. Just curious.
Thanks
PostPosted: Mon Sep 12, 2016 11:58 am
Just to confuse things, below is a page from the black covered factory workshop manual TP832C, and a page from drivers handbook TP828A.
Note that the standard Mini specifications are for cross-ply tyres, some tubed some not, while the Cooper S and Clubman GT have radial ply tyres. Also the comment about increasing the pressure for "high speed driving", whatever that means. :shock:
PostPosted: Mon Sep 12, 2016 1:12 pm
I've run 38 psi in every tire on every vehicle I have owned and never had any issues. The best way to check if you have the right tire pressure is to look at the wear on them, from a quick google search this gives a good description - https://www.kaltire.com/whats-causing-y ... tire-wear/
2015 Ducati 899 Panigale
PostPosted: Mon Sep 12, 2016 1:23 pm
I use 32/30 for my Yoko's, have been for years. Don't remember where I got those numbers from but I get good performance from my tyres and have no unusual wear issues. If I dropped the pressures a bit I guess the ride might be a little better but would it be noticeable? Who knows..
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Mon Sep 12, 2016 1:38 pm
tyre pressure is a very complex thing that changes consistently if you want to get it right
eg on my track bike i run 26r 24f Hot which is around 22r 20f Cold
but depending on the day weather track temp how hard i'm pushing it the cold temps change ]
When we track our Porsche we are looking for 36 Hot front and rear on semi slicks
my road bike I run 30 psi same type of bike as the tracky but driving on the road my tyres don't get hot hence don't heat up the air in my tyres to increase the PSI
My 4by off road I run as low as 12 psi but when towing as high as 45 psi
so in the Mini I run 32 psi seems to work for day to day driving not too much flex, not to soft and not to hard
1968 Morris Mini Cooper S
PostPosted: Mon Sep 12, 2016 2:02 pm
More than half or the tyres I have changed over the years as a mechanic have been from under inflation. I always pump my tyres up with at least 2 psi over the recommended. Then watch the tread wear pattern and adjust as necessary.
PostPosted: Mon Sep 12, 2016 7:33 pm
I agree. Most tyres we see at work are under inflated. I have Pirelli Scorpion's on my BT50 and need to run them at 40psi to get good tread wear. Normally get 100000klms out of them at that, driven hard. With big loads I increase to about 45psi.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
