It is currently Sun Jun 22, 2025 5:26 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Help wet spark plug
PostPosted: Fri Sep 02, 2016 3:18 pm
Going to buy a compression tester now
Lol Grant thought you said it would rev to 10k
1968 Morris Mini Cooper S
PostPosted: Fri Sep 02, 2016 4:08 pm
timmy201 wrote:
exhaust
ɪɡˈzɔːst,ɛɡ-/
verb
1.
make (someone) feel very tired.
"her day out had exhausted her"
synonyms: tire out, wear out, overtire, overtax, fatigue, weary, tire, drain, run someone into the ground, run someone ragged, enervate, sap, debilitate, prostrate, enfeeble; More
2.
use up (resources or reserves) completely.
"the country has exhausted its treasury reserves"
synonyms: use up, run through, go through, consume, finish, deplete, expend, spend, dissipate, waste, squander, fritter away; More
Use up (exhaust) all normal reasons...
:lol:
PostPosted: Fri Sep 02, 2016 4:12 pm
oldblade wrote:
Plugs replaced I am running electronic ignition new leads new coil about a month old
These are the first things I would re-check...maintenance induced faults are quite common :idea:
PostPosted: Fri Sep 02, 2016 4:17 pm
oldblade wrote:
So you saying it could make it run that badly
YES :!:
PostPosted: Fri Sep 02, 2016 6:35 pm
simon k wrote:
does it sound like a tractor?
my bet is head gasket popped between 2 and 3
I'd just about stake my left nut on it
recon your left nut is safe
compression test done
number 2 and 3 low but holds guessing head gasket
PostPosted: Fri Sep 02, 2016 7:17 pm
Before you take the head off put a points dizzy back in and run it. My electronic dizzy started to splutter then dead.
Easy to do may save you a heap of work.
PostPosted: Fri Sep 02, 2016 9:42 pm
What compression pressures did you get?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sat Sep 03, 2016 6:33 am
I couldn't warm the engine up so couldn't get a proper reading but 1 and 4 around 150 and 2 and 3 around 50
PostPosted: Sat Sep 03, 2016 11:49 am
I wouldn't have bothered with a compression test, I wouldn't have even put my thumb over the plug holes
It's a 1275, when they blow headgaskets it's between #2 and #3, if the engine runs badly all of a sudden and sounds like a tractor, and you can pull the leads off #2 and #3 without it making any difference, it's a head gasket
a couple of months ago I found a bloke I know with an 1100 stopped by the side of the road, it had stopped for another reason but was running like crap and sounded like a tractor, pull #3 and #4 off without making a difference (#1-#2 and #3-#4 are the weak point on small bores) - I didn't bother with a compression test - blown head gasket... it had even eroded the head between the chambers
 Post subject: Re: Vacuum your Engine!
PostPosted: Mon Sep 05, 2016 7:23 pm
​http://www.tuneruniversity.com/blog/2011/05/check-your-engines-health-with-a-vacuum-gauge/
PostPosted: Mon Sep 12, 2016 10:59 am
found the issue
PostPosted: Mon Sep 12, 2016 12:36 pm
So the winner of the problem diagnosis competition is Simon. Well done. A chocolate Freddo frog is on its way to you. :)
Your left nut is safe, at least for another day. :wink:
PostPosted: Mon Sep 12, 2016 1:04 pm
Looking at that brown crud, it appears that a good flush of the cooling system won't go astray either. That gasket hasn't seen daylight for years.
PostPosted: Mon Sep 12, 2016 1:25 pm
Interesting enough I just replaced the radiator the water pump and thermostat and at the time I did a flush But something told me there may have been a blockage somewhere when checking with the heat gun it was inconstant.
My coolant stayed green for a few weeks then one day it changed to brown (clog gone)
I said to my wife a week earlier i think the head gasket is about to go as i saw that brown water marks down the front of the engine
PostPosted: Mon Sep 12, 2016 2:09 pm
I reckon you should have the head refaced, and after you've cleaned all remnants of the gasket off the block, get a nice clean (well oiled) oilstone and gently clean the top of the block with it - randomly go all over in all directions - figure eights in different directions etc. etc. You should be able to get it shiny all over including between #2 and #3 where it's dark right now
Users browsing this forum: Bing [Bot] and 2 guests
