It is currently Mon Jul 28, 2025 1:13 am
 Post subject: Re: hydro help
PostPosted: Fri Sep 02, 2016 5:16 pm
Does someone have a photo of the spacer and where it goes, as I don't recall seeing one when fitting the knuckle joints?
PostPosted: Fri Sep 02, 2016 5:27 pm
Spacer goes on the knuckle joint
http://www.minispares.com/product/classic/21A1845.aspx
Part 19 in the image below http://www.minispares.com/catalogues/cl ... x?2~15~132
Or one with built in spacer
http://www.minispares.com/product/Class ... V1264.aspx
PostPosted: Fri Sep 02, 2016 6:23 pm
The suspension was fine before I replaced the knuckles and reassembled
PostPosted: Fri Sep 02, 2016 9:31 pm
Both the front wheels have significant camber not sure if that means something is not seated properly.
PostPosted: Sat Sep 03, 2016 10:09 pm
The lower the ride height at the front, the more negative camber will happen i.e. top of tyre leans inwards/ bottom of tyre further away from centre of car.
