It is currently Mon Jul 28, 2025 12:20 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
 Post subject: Crack testing
PostPosted: Fri Sep 02, 2016 10:36 am
Hi everyone, i have a couple of 1100 cranks and 12g202 heads i will be listing in the next month. Im wanting to make sure none are cracked before listing. How much do those tests usually cost?
Steve
 Post subject: Re: Crack testing
PostPosted: Fri Sep 02, 2016 12:12 pm
$50 in Wodonga...
PostPosted: Fri Sep 02, 2016 12:17 pm
It depends on the test.
`Ping' test costs you nothing. stand on one end on concrete and strike the upper web with a spanner. Turn crank upside down and repeat.
If cracked it will sound flat, whereas a prolonged high pitched ring means (usually) it's good. Note the 2 sprocket shims can damp the sound, I remove them and the crank key first.
Dyecheck- I have a kit here, and do them for $20 if local.
Black light fluorescent- St George Cranks near me charge $80.
Magnaflux- I did this many years ago for nix at work, no idea of pricing now. Ring around welding inspection services.
PostPosted: Fri Sep 02, 2016 12:27 pm
Thanks, i may ping test and list i think. Both are still in blocks, lol
PostPosted: Fri Sep 02, 2016 12:41 pm
Give Ash some flowers Nick .
I've had a crank 'ping' test and sound ok before but upon getting a proper crack test, it had a very fine crack in it. Ping test is cheap though.........
PostPosted: Fri Sep 02, 2016 2:28 pm
I recently sold a couple of crankshafts for a 351W and cost me $120 each for the magnaflux testing here in Toowoomba. Mini would be cheaper due to size but it is a ballpark figure for comparison.
If I sell a crank,or a head, I usually state if it is defective, I just refund the cost of the head plus postage...peace of mind always will prevail and I get all my cranks tested irrespective of condition. I recently bought a new 351w crank and had a hairline crack in the centre web so buying new sometimes doesn't guarantee it is not faulty. Thankfully the business sent me another out pre tested and is perfect plus paid all return and re delivery costs.
Sorry it isn't mini related but have a v8 project on the trot here also...mini for daily and fun and the XD ute for scaring people.
Rob Forsyth
Miniot!!
PostPosted: Fri Sep 02, 2016 3:10 pm
I think i will do a ping test and list on ebay as just taken from engine sutting for 15yrs ( which they will be), i will probably start at 50$ so not worth investing 100$ into it :-) Will say passed ping test if it does and my own visual, but no garuntee :-)
PostPosted: Sat Sep 03, 2016 3:48 pm
I had a dog that used to be great at it. Every lady he came across he use to sniff her for cracks.
"Let us remove your "SHORTS"
PostPosted: Sat Sep 03, 2016 8:12 pm
Thanks for the info on the head and crank. I resolve not to bid. Really !, do you want to risk a bad rating on ebay. Bye bye customers.
PostPosted: Sat Sep 03, 2016 9:56 pm
get them tested and pass the cost onto the customer, that's what I do. Supply and invoice if they're skeptical. If you do this then it circumvents most of the hassle of posting back and forth, which is usually the main aggrevation. It's really not hard to do and everyone wins.
Also a known good crank will sell quicker and for more money than an unknown.
PostPosted: Sun Sep 04, 2016 5:41 am
How much would a tested with invoice 1100 crank go for ( not reground)? I was assuming id be over capitalising?
PostPosted: Sun Sep 04, 2016 8:34 am
FYI I had a couple of cranks for sale, I had them on here and also on facebook groups and listed very genuinely. I had no interest at all, and ended up giving all of them away (minus the primary gears).
viewtopic.php?f=8&t=90727&hilit=crank%2A
I also bought a second hand 1100 crank, which had been crack tested, checked and reground and it was about $200.
PostPosted: Sun Sep 04, 2016 8:36 am
Cool, thanks for the info :-) will get a quote from local engine guy, if too much i will have a couple of paper weights in the shed :-)
PostPosted: Sun Sep 04, 2016 9:00 am
Bear in mind these days a regrind is around $180-200. So if it's already reground (or a mint original) it's worth more than a worn one.
PostPosted: Sun Sep 04, 2016 12:59 pm
Just doesnt make sense to pay 200 for a regrind, 100 for crack test when they are only selling for $200?
