It is currently Sun Jul 27, 2025 10:00 pm
PostPosted: Thu Sep 01, 2016 10:09 am
Today I'm going to install a 2nd hand pinion from Oz on a mates starter motor here in Bali. I didn't bring my workshop manual with me and for the life of me I can't remember if the pinion should be assembled dry or with antiseize/ oil? Can someone enlighten me please. I hope the ring gear is not too chewed up...
Thanks
Michael
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Thu Sep 01, 2016 11:44 am
Put the pinion assembly on the shaft, then lubricate the bendix spline with graphite powder.
PostPosted: Thu Sep 01, 2016 12:29 pm
Thanks Doc will do, if I can find some...
67 Deluxe
Dry suspension
PostPosted: Thu Sep 01, 2016 1:58 pm
if you can't find some, just scribble a HB pencil on some emery paper and wipe it on - same stuff
PostPosted: Thu Sep 01, 2016 6:01 pm
Or just clean and dry the shaft. No lube required.
"Let us remove your "SHORTS"
