It is currently Sun Jul 27, 2025 11:30 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: electronic ignitions
PostPosted: Tue Aug 09, 2016 5:43 pm
GundyGuy wrote:
So where in the UK can you buy one
http://www.accuspark.co.uk/Blackbox.htm
From here but Tony was very reasonably priced and is an expert on them.
PostPosted: Tue Aug 09, 2016 7:22 pm
When fitting electronic ignition systems such as Accuspark is it necessary to run an alternator rather than a standard generator?
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Tue Aug 09, 2016 7:58 pm
No. I run electronic ignition plus black box with a generator no problem.
The other advantage of the black box is that you can retain the original appearance using an original distributor, and yet have access to an almost infinite selection of curves. Everything can be hidden. Only clue is one extra wire to the dissy.
PostPosted: Wed Aug 10, 2016 5:47 am
That link doesnt work if you press Buy it Now
1970 MK2 Cooper S
PostPosted: Wed Aug 10, 2016 7:19 am
I got mine from Rob Roy in Victoria, this before Tony was selling them. Link is in accuspark thread.
PostPosted: Sat Aug 27, 2016 12:16 pm
Just found out AccuSpark have no plans to make anymore of these black boxes
So the question is what if you have one and it shits itself
1970 MK2 Cooper S
PostPosted: Sat Aug 27, 2016 7:08 pm
If the Voltage at the ignition coil drops below 10 Volts when cranking doesn't that tell you that you have something causing too much Draw or drain on the system, ie Starter drawing too much current or could also be that your battery does not have the required reserve capacity that it says on the label. Have you tried doing the correct thing if using a Gemini starter... fitting a starter relay or run the original solenoid to switch the starter Solenoid not the ignition switch. A mini Ignition switch is not designed to handle the current that the Gemini Starter solenoid draws. (Especially if ignition switch is 40+years old)
"Let us remove your "SHORTS"
PostPosted: Sat Aug 27, 2016 11:18 pm
Fitted up mine from tony and can tell you its brilliant. Being able to set your own rev limiter awesome, then being able to adjust the curve your car needs is just brilliant. I am able to work out the ultimate performance for my car and set it up perfectly.
Love the fact that my 68 model car gets programed via my laptop
1968 Morris Mini Cooper S
PostPosted: Sun Aug 28, 2016 5:32 am
I think it will be a hard thing to find in the UK as second hand. They don't keep cars on the road that long there. however these people list as new for sale. http://www.ebay.co.uk/itm/300525275361? ... rmvSB=true
PostPosted: Sun Aug 28, 2016 9:55 am
I also tried looking up accuspark uk on line. Did you actually contact them direct
I would also like one
PostPosted: Mon Aug 29, 2016 9:41 pm
Very simple answer. I will still have them in stock.
PostPosted: Tue Aug 30, 2016 7:33 am
Why Go to the OK to buy a Stealth black Box, an Electronic Ignition Kit, a complete Electronic distributor, Switches and much more Electrical gear for Minis? Especially with today's freight costs from Europe. I specialise in stocking and selling these parts, just Electrical bits. Support your local importers like myself. We buy in bulk to save you money. My prices are very reasonable too. Also as an Auto sparkie that have worked on Minis for most of my time in the trade I know what parts are a good thing and the ones that are not. I test all parts on my own Minis before I stock them and buy in Bulk. I have no interest in selling parts that don't work or last or that are unreliable. Unfortunately there are people who don't read instructions till the part they are fitting does not work and from there they give the parts a bad name. Remember with Electronic stuff you only get one chance to connect it correctly if you don't, these parts blow quicker than a fuse.
PostPosted: Wed Aug 31, 2016 7:59 pm
Hi Tony
Can you please pm with a price of a box to Nz please
Ta
Bernard
PostPosted: Thu Sep 01, 2016 6:10 pm
another thumbs up from me for Tony aka Convertible Mini's 'leccy distributor
a cheap and easy fix to a problem and have had no probs since installing a year or two back now
1968 Mini-Matic
