It is currently Sun Jul 13, 2025 4:18 am
PostPosted: Sat Aug 27, 2016 9:48 pm
1.25 su alloy inlet manifold is there such a thing
PostPosted: Sat Aug 27, 2016 10:01 pm
Not that I've ever seen. The old tuning companies would separate the factory cast intake/exhaust manifold and do some porting work. You'd be better off with an HS4 most of the time anyway, or twin HS2
Minisport make an adaptor bracket if you really want to keep the HS2..
http://minisport.com.au/mini-su-adaptor ... n-to-1-1a4
PostPosted: Sat Aug 27, 2016 10:05 pm
currently have the cast joined as you said might cut and separate
PostPosted: Sun Aug 28, 2016 1:17 pm
yes. they come up from time to time on ebay uk. I think alexander made one type.
PostPosted: Sun Aug 28, 2016 2:23 pm
Lynx used to make a alloy one too
PostPosted: Mon Aug 29, 2016 6:36 pm
Didn't the Sports 850 use twin HS2s???? Admittedly it was along time ago ..and there weren't many.... so you will probably need to look hard :)
Way back when I had an 850 with twin HS1s .. I think they share a common mount.
Cheers, Ian
PostPosted: Mon Aug 29, 2016 7:32 pm
That is right. I bought one from Lynx when I fitted Sonic LCB extractors to the mini K.
PostPosted: Mon Aug 29, 2016 8:02 pm
Cheers, Ian
I think he wants a single SU manifold, or have I misread?
PostPosted: Mon Aug 29, 2016 8:06 pm
I read it as single HS2 manifold.
PostPosted: Mon Aug 29, 2016 8:30 pm
I think old Morris minors and Austin A30's had two piece manifolds.
PostPosted: Mon Aug 29, 2016 8:42 pm
and the north/south a series had a different carb mounting angle as far as i can remember.
PostPosted: Mon Aug 29, 2016 8:58 pm
single will in the future cut the cast
PostPosted: Tue Aug 30, 2016 7:57 pm
High heel ninja
you can buy a heated UK type manifold and fit a adaptor to take a 1 1/4 su. Minisport.com.au have them
PostPosted: Tue Aug 30, 2016 9:04 pm
This is a manifold I have, do not know how old it is. have had it a long time, 20 years plus at least.
can be drilled for 1 1/4, 1 1/2, 1 3/4. not for sale, just putting the info out there.
I have seen a few pop up for sale.
Why is it the things that make me tick, are also the things that make me go boom?
PostPosted: Mon Jan 07, 2019 6:41 pm
I purchased a lynx manifold online similar to this, thinking it would fit a HS6. When it arrived, I measured the inlet and it's much smaller than 1.75", it was closer to 1.25" to suit a HS2...
Is the manifold shown here the same casting but just ported to suit a HS6? Or are they a different beast?: viewtopic.php?f=2&t=87235
Pictures attached of the one I bought:
