It is currently Sun Jul 27, 2025 8:03 am
 Post subject: Re: clunk in front end
PostPosted: Sun Aug 21, 2016 3:35 pm
69k1100 wrote:
what's the end float on the top arm like?
about 0.003" if that
1970 MK2 Cooper S
PostPosted: Sun Aug 21, 2016 3:37 pm
sitnlo62 wrote:
Worn spline on the drive coupling and drive shaft can cause the problem you are describing.
Also CV to drive flange spline worn or loose.
What about worn Uni's?
1970 MK2 Cooper S
PostPosted: Sun Aug 21, 2016 8:13 pm
Bad Universal joint will give vibration while Driving.
That Clunk on take off happens when spline wear takes up as load is applied.
PostPosted: Sun Aug 21, 2016 10:07 pm
Hydro bag not locked into subframe
Mark
PostPosted: Sun Aug 21, 2016 10:09 pm
Did you grease up your knuckles after you installed them ?
PostPosted: Mon Aug 22, 2016 5:40 am
Are you supposed to grease them :mrgreen:
1970 MK2 Cooper S
PostPosted: Mon Aug 22, 2016 8:19 am
New knuckle joints don't have much grease in. I give mine a shot with a 'grease needle' and the grease gun every 2 years.
PostPosted: Mon Aug 22, 2016 12:53 pm
Come on Gundy, are you kiddin, r u taking the piss ?. Grease em up man ! I'd also wack a few squirts of crc between the knuckle and nylon bush.
PostPosted: Mon Aug 22, 2016 4:25 pm
Gee mate you BITE WELL
If i do anything i would over grease things
Just as i did when it was rebuilt
I actually removed the grease that they came with and put in something of a known origin.
Not Tibetan Yak Snot
1970 MK2 Cooper S
PostPosted: Mon Aug 22, 2016 8:32 pm
When I bite I bite hard. Go "no yak snot" Gundy. Love that, cheers.
PostPosted: Sat Oct 29, 2016 4:47 pm
Did anyone ever happen to find the issue here?
PostPosted: Sat Oct 29, 2016 5:02 pm
NO
It still make strange noises
1970 MK2 Cooper S
PostPosted: Sat Oct 29, 2016 8:24 pm
The tie bar to lower control arm bolt? Worn holes?
Users browsing this forum: Bing [Bot] and 93 guests
