It is currently Tue Jul 15, 2025 12:12 pm
 Post subject: Chrome side moulding
PostPosted: Wed Jul 13, 2016 9:12 pm
I have just installed chrome side mouldings on my 66 Deluxe. They came up a treat by utilizing a hair dryer on the 2 tight bends. Overall they are a tight fit but I'm guessing a speed they would work their way loose. Are there clips available to hold them on or do I install pop rivets on the underside, or are there any other tricks to keep them retained. Thanks.
 Post subject: Re: Chrome side moulding
PostPosted: Wed Jul 13, 2016 9:45 pm
Rivets will damage the trim, use trim clips ala
PostPosted: Wed Jul 13, 2016 9:53 pm
Thanks DOZ. Are they the door rubber trim clips for wind up windows.
PostPosted: Wed Jul 13, 2016 10:01 pm
no idea. Mine were held on with rivets in 4 spots on each side (either side of the wheel arches). I've seen these trim clips used on other cars.
Maybe someone else can tell us both as I will be putting new ones on for Bathurst
PostPosted: Wed Jul 13, 2016 10:56 pm
My MK1 S has the moulded side strips and they are only pushed on. However I put a set of the standard side strips on my Clubby last year and it needed a rivet at the front and back. I haven't tried any type of clip.
PostPosted: Thu Jul 14, 2016 1:09 am
I put these on the other night, http://minisport.com.au/chrome-plastic- ... of-the-car
Took less than 5 mins each side, no clips or rivets or heat and it was cold about 10c. Couldn't believe how easy it went on.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Thu Jul 14, 2016 9:20 am
When talking to John S, he suggests nothing at first, then clips, then if all else fails rivets.
speaking of which i need to redo mine.
Nick
PostPosted: Thu Jul 14, 2016 11:27 am
Thanks guys. I have a few of those clips that DOZ suggested. I have a bit of time on my hands before she hits the road. Will wait till then and allow for any stretching then put a few on. I think one at each end, one at each end on the straight bit before the bends, nothing on the wheel arches.
PostPosted: Thu Jul 14, 2016 4:51 pm
If you need more clips NOS ones are quite inexpensive.
http://minikingdomonline.com.au/product ... g-kit-nos/
PostPosted: Thu Jul 14, 2016 7:36 pm
I have used S style plastichrome mould on my mini K without flares - no clips or pop-rivets - just sits in place. It's a bit harder when fitting to plastic flares.
By the way, the factory accessory flare kits came with the same trim clips used on the vertical seam covers - a simple U-section with barbs on both sides. I have never used them so don't know how well they worked as most of the moulds grip without any extra help.
PostPosted: Thu Jul 14, 2016 9:32 pm
Thanks for the info guys. Much appreciated.
PostPosted: Tue Aug 02, 2016 10:47 pm
We glue them on the race car as they come loose at speed.
Contact adhesive and then push them on.
PostPosted: Wed Aug 03, 2016 8:45 pm
the vertical seam cover clips are not the same as the ones for the cooper s side moulds
if you look at the two , you will see that the side mould clip has a angled raised edge on one side only
this edge hooks behind the top edge of the side mould , the under side is flat other than the barbs that lock onto the metal lip
When my cooper s moulds where put on , there where no clips and no rivets
over time as the mould shrunk , expanded and hardend to the shape of the car edge they became loose
this is when I put clips in , and only where the mould was very loose on the seams
I found it better to pull the mould back slightly , put the clip in the mould , not on the seam , and push it back on the seam
Over a 4 year period I would probably have put on a total of 12 clips. and not on the tight bends neither
just my 2 bobs worth
Mark
PostPosted: Wed Aug 03, 2016 9:55 pm
Good info slacko, much appreciated.
PostPosted: Fri Apr 20, 2018 11:42 am
In case it's of interest here's what the factory advised on fitting the earlier flat side moulding. Probably the same for the Cooper S style.
Users browsing this forum: Bing [Bot] and 109 guests
