It is currently Mon Jul 28, 2025 5:57 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: Starter motor
PostPosted: Sat Jul 30, 2016 4:04 pm
zulu_warrior1976 wrote:
Hmm, so a tune required then? Seems to run ok when it has started.
I'll check out the starter motor but I agree that it seems to be doing what it needs to do.
I may need to try just a touch of choke too rather than none.
Unless you are living in Marble Bar say...pull the choke out when the engine is cold...that's what it is there for :idea: :D
PostPosted: Sun Jul 31, 2016 9:55 am
98 ulp
the choke linkage set up properly and actually doing something?
I'm with Simon ,i had the same problem with my mini years ago , was a pig to start when it hadn't been run for a while ,would do exactly as you say yours is doing, ( i run twin SU's ), checked the choke , set it up properly, haven't had an issue since .
SU's love choke , give it full choke :wink: .
PostPosted: Sun Jul 31, 2016 7:58 pm
Or go a weber /dellorto...one full pump, release then a quarter pedal and the thing starts before I can release the key. The choke will keep it running until it is not as cranky.
Hooroo
Rob Forsyth
Miniot!!
Users browsing this forum: Bing [Bot] and 88 guests
