It is currently Mon Jun 23, 2025 1:47 pm
 Post subject: Most hp from an A series
PostPosted: Fri Jul 29, 2016 7:59 pm
Ive watched as my bro (Babes) has built up his basically std metro turbo block and bolted on eaton supercharger.
It runs decent engine management and a lot of custom fabrication for a result of 140whp which must be 160 ish at the crank.
I figure 200hp at the crank should be achievable.
Has it been done before? try and keep answers factual please :lol:
PostPosted: Fri Jul 29, 2016 8:26 pm
have a look at turbominis.co.uk... they're making lots of power
PostPosted: Fri Jul 29, 2016 10:34 pm
Milatsmadmini
As simon says... (heh)
Those UK blokes are doing old school turboing (low comp, big lag stuff) but making pretty massive figures.
Im currently building up a small bore hoping for 100hp at the wheels with good off boost driveability which should be achieved with decent static compression
PostPosted: Sat Jul 30, 2016 6:13 am
IIRC 200 HP was the power the Metro Turbo Cup cars made back in it's days.
Rover 214 atm ....
PostPosted: Sat Jul 30, 2016 8:21 am
Online
This speed record chasing car was making 280hp with under 1000cc... Not super reliable from the sound of the article though.
http://bmcexperience.com.au/bmce-issue4/project-64.html
PostPosted: Tue Aug 02, 2016 3:54 am
Turbo ? entirely possible, Roberts mini is running 250 isch Banannas, he knows what he is doing though and has been sticking turbo's on everything he drives, even his motorbike for decades :)
the project 64 guys. you have to remember that Bonneville is a pretty brutal place, hot, high altitude and WOT for several miles pulling very long gears . Stuff does break.
350bhp on methanol probably more now but it is just an a series short block(ish)
https://www.instagram.com/p/BIlDxJOB20Z/
Try breaking 155 BHP at the crank normally aspirated with a 5 porter, it is a lot more interesting ;) and expensive, and gives you headaches.
no time to finish me bleedin car ..
1982 Blue-White Roof.
http://aseriesmodifications.wordpress.com/
PostPosted: Sun Aug 07, 2016 9:51 am
Thanks for the replies and links :D
Wow 350 is way more than i was expecting.
Interesting they are using 970 block :idea:
PostPosted: Sun Aug 07, 2016 1:16 pm
you should read back on it, pretty sure it was to qualify for a particular class - under 1 litre I guess
it's a great story too
