It is currently Mon Jul 28, 2025 6:01 am
 Post subject: Heater question.
PostPosted: Sat Jul 16, 2016 6:12 pm
I bought this heater in the picture from England about 5 or 6 years ago. I was just wondering if it was from a Mini or not. It looks right and fits in the space but the core outlet and inlet come out on the right hand side. If that is correct do the heater hoses go over the top or underneath to go out the holes in the firewall? It is going in a 69 K, i have some brackets that I hope will be ok for it. I need to attach them as well. Thanks, any advice is appreciated.
Steve
 Post subject: Re: Heater question.
PostPosted: Sat Jul 16, 2016 6:16 pm
it looks like a MK1 S type, except for the control panel on the front and the hoses coming out the wrong side...
PostPosted: Sat Jul 16, 2016 6:34 pm
Like this one? http://www.minispares.com/product/classic/JEC10109.aspx
PostPosted: Sat Jul 16, 2016 8:59 pm
That Certainly look like the one, I guess I will try and fit it and then I think taking the hoses over the top should work. hopefully the angles wont be too much.
Steve
PostPosted: Sat Jul 16, 2016 9:05 pm
Sometimes there are holes in the l/h side and you can pull heater apart and turn the core around
PostPosted: Sat Jul 16, 2016 10:03 pm
Yep, weird isn't it? That model is the same as Moke's from the 70s and Rover minis until they went to the plastic body version. Tuck the hoses up behind it while pivoting up into position.
M
PostPosted: Sun Jul 17, 2016 6:28 am
Maybe it is one for a LEFT HAND DRIVE CAR !
"Let us remove your "SHORTS"
PostPosted: Sun Jul 17, 2016 4:04 pm
It's a standard mini from a mk3 mk4 mini.
Standard fitment to most nz . Uk minis
Just fitted one to my car this weekend
Worst job in a mini and they rattle when installed
PostPosted: Sun Jul 17, 2016 5:44 pm
Thanks guys, There are no holes in the left side, that would have been good if there was. Hey Kiwi where did the hoses go when you fitted yours, they might get a bit close to the clutch pedal if the bend is too big as well.
Did they make left hand drive Minis? How would the clutch work with such a long hose to the slave cylinder?
Steve.
PostPosted: Sun Jul 17, 2016 6:16 pm
Steve.
The flexible clutch hose connects at that same point for LHD and RHD. On LHD there's a long brake pipe from the master cylinder across to the firewall bracket.
PostPosted: Sun Jul 17, 2016 6:21 pm
This is how BMC designed the brake and clutch pipes to accommodate steering from either side.
I'm not aware that any LHD Cooper Ss (YDO6) were produced in Australia. Anyone know?
PostPosted: Sun Jul 17, 2016 9:16 pm
1/2" drill bit ?
PostPosted: Sun Jul 17, 2016 10:05 pm
Pretty sure thats from a l/h drive mini and yes they did make l/h drive minis.I had one in Europe
Sent from my SM-G900I using Tapatalk
PostPosted: Mon Jul 18, 2016 3:04 pm
DID THEY MAKE Left Hand Drive Minis ? The answer is YES. More than right hand drive ones believe it or not.
PostPosted: Mon Jul 18, 2016 3:13 pm
Thanks guys, but you missed the important word AUSTRALIA in my question. :wink:
I've spoken to someone who worked there and would know, and he thinks no LHD Minis were actually assembled at Zetland even though the engineering work was done in case it was required as part of a Special Production Order (SPO).
Users browsing this forum: Bing [Bot] and 78 guests
