It is currently Sat Jun 21, 2025 4:34 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Jul 12, 2016 8:11 am
hi Dalmeny
Re tooth count: 10 seems to be the new norm, with the advent of pre engaged in the mini. My understanding ( so others please feel free to correct) is the tooth count between 9 and 10 can both be correct, but the chamfer/shape of the teeth (should!!!!) be slightly different profile..... think along the lines of the different ratios you can achieve in drops gears 23/30/24 24/30/23 etc,,,
so theoretically the teeth count is not an absolute BUT this assumes the slight mods have been made so the teeth slot and mesh well.
so original starters and interia type replacements tend to be 9 teeth as per KLAS
the pre engaged types usually 10 teeth.
11 teeth,,,,,???? not sure , again not IMPOSSIBLE but not usual in a mini
PostPosted: Tue Jul 12, 2016 10:44 pm
all starter motors i have are pre engaged, and recount the teeth to verify. all 3 i have at hand have 9 teeth. all made in the 1990s type M79.
Rover 214 atm ....
PostPosted: Wed Jul 13, 2016 9:49 am
If someone knows more about the relationship between pre engage / pinion count etc, it would be good to get more info.... KLAS's info seems to disprove the pre -engaged more likely to be 10 teeth theory.
PostPosted: Thu Jul 14, 2016 3:40 am
maybe quite interesting, i searched for hi torque starters here in Germany. the only dealer who states numbers says his hi torque starters all have 9 teeth, no matter if for pre engaged or inertia ring gear. the difference is the diameter, 25mm for pre engaged, 29mm for inertia
Rover 214 atm ....
PostPosted: Thu Jul 14, 2016 8:48 pm
Been doing a bit of homework on the starter. It looks like what they use in some Toyota's with a suitable pinion gear to suit the application and obviously the mini mount screwed on the end. My Auto sparky has already come up with a pinion gear that is one millimeter bigger in diameter and a better profile match, still 11 teeth. Ring gear will be here in 8 days I'll get it fitted work out the pinion once the flywheel and starter are set up again.
Dalmeny
PostPosted: Fri Jul 15, 2016 2:27 pm
Did you get a response from MED, I have used them many times in the past and never had a problem with them or their products.
I am sure they would be willing to get it sorted.
Grant
100% Pure A Series Turbo
PostPosted: Fri Jul 15, 2016 11:26 pm
Yeah, no problems with MED always quick to reply and receive goods within 8 days. Obviously they only saw pictures, but that's the right pinion gear as far as they use (with the 9 tooth and 29mm diameter). They couldn't see a fault just wear and tear. Hard to argue this far away. New ring gear 30 pounds plus 35 pounds shipping. The only thing I have to work out with the engineer is how we fit it. The original set up has 6 grub screws drilled and tapped where the ring gear meets the flywheel i.e half the thread in the ring gear and half in the flywheel. Or just tack weld in 6 places. The pinion gear can be sourced locally.
Dalmeny
PostPosted: Sat Jul 16, 2016 1:06 pm
All the `Matics had the ring gear just tacked on. Ditto the current Minispares light race Mini flywheel
If you weld it on, space the tacks equally and of equal length or you will have more metal removal to balance it.
I was amazed how far out of balance a brand new Minispares flywheel was recently.
PostPosted: Tue Jul 19, 2016 7:35 pm
Ring gear arrived today. Not bad 6 days from UK, order date 14/7. :D
Dalmeny
PostPosted: Tue Jul 19, 2016 8:49 pm
Better than auspost!
Zulu...
1967 mini Cooper S
PostPosted: Sun Jul 24, 2016 11:56 am
I too have been getting "big noises" from my aftermarket starter. Mine's one of these.
http://www.powerlite-units.com/products/rac468/
Bearing in mind that it is for a Verto flywheel, the pinion is about 29mm dia. and 11 tooth.
The issue here seems to be the pinion clashing with the face of the ring gear, rather than taking the top of the teeth off the ring gear.
Interested to hear what people think of this particular variation on the problem!
'68 Deluxe w/Metro engine
PostPosted: Sun Jul 24, 2016 9:46 pm
Yeah same starter and pinion gear as mine. But, is your ring gear inertia or pre-engage. When ordering the ring gear from MED it had to be a pre-engage ring gear.
Dalmeny
PostPosted: Mon Jul 25, 2016 7:31 am
Mine is a pre engaged ring gear, as it is a verto (and the power unit came with a pre-engaged factory starter).
PostPosted: Mon Jul 25, 2016 8:34 pm
First think I would do is power up the starter on the bench and make sure it is throwing out. If it is pull the pinion out and measure the distance from the mounting plate to the end of the pinion gear and compere the measurement from the flywheel housing to the ring gear. Or, jam the pinion gear out as far as it will go with a spacer, mount it back to the flywheel housing and have a look through the grommet hole with a camera.
Dalmeny
PostPosted: Mon Jul 25, 2016 8:48 pm
Thanks- - good idea - will do.
BTW It seems there is an inertia starter ring gear (107teeth) for Verto and a pre-engage ring gear (129teeth) (for Verto). My previous post suggested that a Verto flywheel was for pre-engaged only - which some readers would know is not correct. This is from the old Mini Kingdom catalogue....
Users browsing this forum: No registered users and 24 guests
