It is currently Mon Jun 23, 2025 6:53 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: Thrust washer help
PostPosted: Sun Jun 19, 2016 3:17 pm
Thread revival.
I have been measuring two engines back to back. A stock 1100s and my Moke block with AEG480 crank with the stuffed thrust bearings. I can confirm ^^^ above about the thrust bearing thickness.
Can anyone tell me how I can source a set of thrusts that are the correct thickness to suit an 'S' crank in a non-S block? I know that posts above say to get std ones ground. Where in Brisbane should I go for this? Do any of the shops offer these as an off the shelf part?
The stuffed set I have pulled out had been ground and then a couple had been sanded a bit here and there to get them right. I don't know what caused them to be stuffed. Nobody has come up with any suggestions on my build thread. Probably just crap in the oil galleries. All the measuring I have done suggests they would have had very close to 0.005" end float before the bearings picked up metal.
As soon as I get replacement thrusts I can reassemble this engine.
Thanks,
M
PostPosted: Mon Jun 20, 2016 8:03 am
Take a new set of std thrust bearings to a toolroom, they can grind them as a set on the surface grinder using their magnetic chuck.
Note:
1. make sure the washers are flat to start with.
2. Only grind the backing, not the copper face.
3. Put a sheet steel strip on the chuck each side of the washers, so they are held more securely.
I used to do my own this way, back when I had a job..!
PostPosted: Mon Jun 20, 2016 2:21 pm
what about on this sort of surface grinder Kev?
it's what I've used to do a few things like idler gear thrust washers and the crankshaft C washers I had made
PostPosted: Mon Jun 20, 2016 8:19 pm
Guy did mine did very well .Took two goes due to my limited measuring skills but I now have 7 thou for the stroker crank end float .They are mirror finish.As per Doc a machine shop with magnetic ability.
PostPosted: Mon Jun 20, 2016 9:01 pm
Sure Simon that is the type to use. Toolrooms have bigger exxy ones but they do the same job
PostPosted: Tue Jun 28, 2016 8:51 pm
Mines all sorted As kevs advice find the right machine shop
