It is currently Mon Jul 28, 2025 9:14 am
 Post subject: front drum brakes.
PostPosted: Sat Jun 18, 2016 8:59 pm
How many people still have all wheel drum brakes and are you happy with their performance?
 Post subject: Re: front drum brakes.
PostPosted: Sat Jun 18, 2016 9:20 pm
Yes, fitted larger 1" bore front wheel cylinders and they stop more than well enough for a road car.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Sat Jun 18, 2016 9:37 pm
That's good to hear. I was looking at the mintex shoes and the 1" bore wheel cylinders instead on paying the cost of the cooper S set up.
PostPosted: Sat Jun 18, 2016 10:35 pm
The trick with the drums is to start with new everything and adjust & bleed every year.
PostPosted: Sat Jun 18, 2016 11:11 pm
I need to build the brakes from scratch. Is there any benefit from fitting braided brake hoses over rubber hoses?
PostPosted: Sat Jun 18, 2016 11:34 pm
Standard hose is all you need for a road car.
PostPosted: Sat Jun 18, 2016 11:43 pm
At least that will save me a few dollars.
PostPosted: Sun Jun 19, 2016 6:40 am
Be aware mounting holes for 1" cylinders are deliberately different to 15/16" ones. You need to file them to fit.
PostPosted: Sun Jun 19, 2016 8:17 am
Mine are fine, I have no problem even on long downhill runs.
As mentioned above, the key is having them adjusted properly. It makes a big difference to the pedal height and feel.
PostPosted: Sun Jun 19, 2016 8:45 am
We're are the 1" cylinders available from
PostPosted: Sun Jun 19, 2016 9:26 am
".....Mine are fine, I have no problem even on long downhill runs. .."
Then you obviously drive conservatively..... I drove an 850 for years and though the brakes were fine..until I switched to discs.
Drums will stop every bit as well as discs ..once or maybe twice... Why do you think Jaguar (and BMC) went to discs in the first place... The Laws of Physics apply ..as the fluid heats up the brakes go away.. and discs are better at getting rid of the heat..
Wheel cylinder size does nothing except change the ratio of pedal to pad pressures.. much like a booster. The bigger the slave bore the lower the pedal pressure for the same braking effect - at the expense of pedal travel.
Cheers, Ian
PostPosted: Sun Jun 19, 2016 9:56 am
I got mine from Minisport in Adelaide. As the Doc said be prepared to file a bit to make them fit.
I rebuilt my brakes completely last year. Hoses, had my 1 inch cylinders resleeved in stainless, rebuilt the master cylinder. My shoes and drums were good still. My brakes are now fantastic. Changing the fluid regularly helps too.
TOO MANY MINIS AND NOT ENOUGH TIME
PostPosted: Sun Jun 19, 2016 11:32 am
My mini when I bought it came with 4 spaced drums and the longer wheel studs so I can run the Cooper S wheel arches or no flares with the standard drums. I just need to get all the bits and pieces for the drum brakes.
PostPosted: Sun Jun 19, 2016 11:40 am
The 1" cylinders where slightly tight in the backplate, but went in fine without any modification.
*witty signature*
PostPosted: Mon Jun 20, 2016 9:22 am
What are some of the better shoes to use?
Users browsing this forum: No registered users and 31 guests
