It is currently Mon Jul 28, 2025 1:59 pm
 Post subject: Cast iron welding
PostPosted: Sat Jun 11, 2016 2:15 pm
I have a block that has suffered damage to one of the locating stud holes to gearbox.
Accident damage.
It needs a copper round insert to be made to weld with what I think are these
gemini 98 welding rod for cast iron.
There is still half a hole there .Should I even bother.
Thanks Ian
 Post subject: Re: Cast iron welding
PostPosted: Sat Jun 11, 2016 4:02 pm
Can you drill and tap it further in?
PostPosted: Sat Jun 11, 2016 5:24 pm
I would weld the boss up solid with castcraft 100 (100% nickel) electrode then re-machine the hole on the mill.
The nickel deposit is fully machinable.
PostPosted: Sun Jun 12, 2016 10:26 am
Thankyou :!:
