It is currently Mon Jul 28, 2025 1:53 pm
 Post subject: Decoking?
PostPosted: Mon Jun 06, 2016 4:01 pm
Hi,
My engine is in pieces because I'm installing a new camshaft (Doc will be pleased to hear it's the RE 282). The engine has only done 15000 km since full overhaul, do I remove the carbon from the piston crowns or leave alone. I'm in two minds, don't want loose crud to get between pistons and bores.
Also, should I take the bearing caps off for a looksee or again leave alone. Before dismantling the engine was perfectly healthy, 240 psi compression pressures and good oil pressure.
Thanks
Mikal
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
 Post subject: Re: Decoking?
PostPosted: Mon Jun 06, 2016 4:07 pm
I would leave the bearings alone & go get a can of carby clean & clean off the pistons & use an old rag to wipe off the debris.
Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
PostPosted: Mon Jun 06, 2016 6:50 pm
What Brad said ^^
Smear some grease around the top of the bores then turn pistons past tdc, wipe grease off.
Users browsing this forum: Bing [Bot] and 83 guests
