It is currently Mon Jul 28, 2025 1:55 pm
PostPosted: Sun Jun 05, 2016 2:00 pm
Hi,
Dropped rear subframe from mini van today and went to remove subframe mounts. Discovered that the front mounts have what looks like a plug with 2 holes on end of the mount shaft and I have no idea how these can be remove to take off the mount.
The shaft the mount sits on simply spins when I use molys and I don't have adjustable grinder spanner (not that I think that would help).
Clearly I'm missing something, any help would be great ?? I can post picture if not clear in case this is model specific.
The back mounts were nuts and easy to remove.
Thanks in advance.
PostPosted: Sun Jun 05, 2016 2:33 pm
The round thing is the head of a `mount pin', ie. it is a glorified bolt.
There is a nut inside the subframe when you clear all the crud away.
PostPosted: Sun Jun 05, 2016 7:35 pm
An angle grinder key / tool makes a useful holding devide for the trunnion pin when loosening the bolt.
:D
Users browsing this forum: Bing [Bot] and 79 guests
