It is currently Mon Jul 28, 2025 1:49 pm
PostPosted: Sat Jun 04, 2016 9:16 pm
Hi,
I have taken the steering column out and noticed how the upper bracket is held by bolts which go through the upper dash rail down through the bracket. The metal is quite flimsy in the rail. I have recently noticed on minispares catalogue a bracket that is meant to support the dash rail with the bolts going upwards into it:
http://www.minispares.com/product/Class ... o%20search
it does not say which model minis have this. I was just wondering if minis were meant to have this bracket and the previous owner has messed it up?
Thanks
Steve.
PostPosted: Sun Jun 05, 2016 12:26 am
One bolt goes through the pedal box which gives it plenty of support. Australian cars didn't have that plate (not that I've ever seen anyway)
PostPosted: Sun Jun 05, 2016 6:49 am
clubby shape got that bracket 73 on I think?
PostPosted: Sun Jun 05, 2016 9:56 am
That sounds about right Rob.
Why is it the things that make me tick, are also the things that make me go boom?
PostPosted: Sun Jun 05, 2016 10:04 am
Was so the steering column could move in a accident
PostPosted: Sun Jun 05, 2016 11:19 am
Thanks everyone.
Hmmm...I'm guessing from 75 on the steering column used shear bolts etc? Anyway, I was really seeing if my round nose was meant to have them. I have had a bit of a look and from the parts lists on mini kingdom it looks like it was used in UK minis with a different upper steering column bracket.....
PostPosted: Sun Jun 05, 2016 1:25 pm
Roundy here had a different pedal box, as Simon says, bolt goes through the box.
PostPosted: Mon Jun 13, 2016 2:48 pm
Got it on my 78 1275
1978 Leyland Mini 1275 LS
Hi Ho Silver and hopefully away
