It is currently Mon Jul 28, 2025 1:40 pm
PostPosted: Wed Jun 01, 2016 1:08 pm
This poor girl is a bit worse for wear ..
Anybody have one lying around ?
If not I will go about remaking some of the panels..
Question though .. That colour ( the olive silver) is that the original colour ? An undercoat or plating ?
Many thanks gents
S
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Wed Jun 01, 2016 2:55 pm
They were all painted black. Not sure if plated underneath.
PostPosted: Wed Jun 01, 2016 11:45 pm
I have one. The top mounting tabs have broken off but the rest appears fine, like not rusty but certainly not restored.
M
PostPosted: Thu Jun 02, 2016 5:03 am
I have one here , i can get you a pic . It appears from the discussion on it that it is the earlier type, has 3 legs .
PostPosted: Thu Jun 02, 2016 9:31 am
The Mini King
As Dr Kev mentioned, they were all painted black.
they were never plated. It appears to me that this has been
chemically cleaned, and if I am correct that would account
for the colour
PostPosted: Thu Jun 02, 2016 9:37 am
There were 2 types-
Early ones had 3 bolts, later ones had 2 bolts at top and a V rubber (like a Moke bonnet hinge one) at the bottom, which sat in a |_| shaped bolt.
PostPosted: Thu Jun 02, 2016 9:50 am
Yes John that may be the reason as I caustic bath all of my bits before restoring them ...
This silvery tone comes up often
On the backing plate for example.
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Jun 02, 2016 9:52 am
The one I have is the later one then Doc.
Would that have been correct for a late 68 ?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Jun 02, 2016 10:13 am
Not sure when that came in. Mine is 3/70 and has it, so did a 69 one that I had.
PostPosted: Thu Jun 02, 2016 4:48 pm
The Mini King
Yes it is the correct one for 1968
PostPosted: Fri Jun 03, 2016 7:38 pm
http://www.ebay.com.au/itm/Morris-Mini- ... Sw9eVXUSDh
PostPosted: Fri Jun 03, 2016 9:21 pm
Goldbrocade_62 wrote:
http://www.ebay.com.au/itm/Morris-Mini-850-Deluxe-Heater-Box-/222139776186?hash=item33b88ffcba:g:KkMAAOSw9eVXUSDh
This is the early one. It will require you to drill a hole on the inner panel and remove the bracket.
Justin
PostPosted: Fri Jun 03, 2016 9:44 pm
It is could be modded if needed or make one from 2
Users browsing this forum: fuzzy-hair-man and 95 guests
