It is currently Wed Jul 23, 2025 4:35 pm
 Post subject: First Mini :)
PostPosted: Sun May 29, 2016 10:38 pm
Hello,
Just brought my first mini a couple of weeks ago and have been trying to confirm what year it was and what the original colours are?
The only plate on the body I've found is XA2S2 0558438P
And the engine number has been stamped in to the block is 99H905AJH001389
There is also an Australian Mod Plate
If any one could steer me in the right direction with this?
Thank you
Nic
 Post subject: Re: First Mini :)
PostPosted: Sun May 29, 2016 10:41 pm
Got a photo of the outside of the car?
Nearly seems like it could be an early 70s UK mini.
PostPosted: Sun May 29, 2016 10:52 pm
Only one i have. brought the car mostly stripped already
PostPosted: Sun May 29, 2016 10:59 pm
Yep - Mk3 import. Probably 71-73 ish.
I can't tell you it's original year or colour but being British built, British Motor Heritage would be able to tell you everything down to the day it was made.
PostPosted: Sun May 29, 2016 11:04 pm
thank you very much
PostPosted: Mon May 30, 2016 5:51 am
Is a rare car over here
PostPosted: Mon May 30, 2016 7:20 am
Maybe take one of the id plates off and see what colours behind
PostPosted: Mon May 30, 2016 12:08 pm
Thank you all for your help.
PostPosted: Mon May 30, 2016 12:32 pm
As someone said, you could apply for the heritage certificate. For not a lot of money, you will get the full story of your car as it rolled off the production line. Pity we can't do that for Australian produced models.
That would be preferable to taking a tag off unless you plan a ful, re spray/ resto anyhow.
PostPosted: Mon May 30, 2016 12:41 pm
The codes on the mod plate are for certifying compliance for the install of seat belts (LK1) and with ADR's (LO1), and as it also has the date 12/72 on the same line, I would expect they are claiming it has a December 1972 build date.
The seatbelt requirements as with many ADR requirements relate to the vehicle build date - hence its inclusion.
Also, as the mod plate date appears to be April 2000, it would indicate it probably was imported in 1999 or early 2000.
Tim.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Mon May 30, 2016 12:48 pm
Manta wrote:
Hello,
Thank you
Nic
Welcome Ray (Nic)...put where you are located approximately in your profile so that people can tailor their advice to you :idea: :D
PostPosted: Mon May 30, 2016 1:40 pm
Unfortunately by the time the Clubman came along the factory records were not what they used to be.
Once upon a time you could get a full build record for $5. Today we're not so lucky.... Have a look at the website and see if you're happy to pay for what level of service they are offering for your model...
Other wise I would be looking carefully at the firewall behind where the heater fits or at the top area behind the dash trim for original paint.
XA2S2- indicates a UK built Clubbie somewhere between 69 and 74... (http://new.minimania.com/Mini_Chassis_V ... __Revised_)
Cheers, Ian
PostPosted: Mon May 30, 2016 5:22 pm
Early ones have hydro suspension
