It is currently Mon Jul 28, 2025 9:25 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Mar 02, 2016 4:40 am
Contessa nuts seat only on the chamfer inside the washer. The corners of the nut are not in contact and would have a slight chamfer too.
PostPosted: Wed Mar 02, 2016 5:46 am
Thanks doc. I will pass on the info.
PostPosted: Wed Mar 09, 2016 10:07 pm
Just another update. I've looked over some detailed drawings and have given them the thumbs up for production.
With regards to pricing, they will be $140/set for the larger sized 3/4" or 19mm nuts. This includes 16 tapered washers.
Stay tuned for the pics...
I will post up some detailed pics as soon as I receive the first shipment.
PostPosted: Fri May 27, 2016 9:36 pm
With some teething problems and a lost batch, they are finally here.
As requested, these have been tapped a further 5mm (compared to original flat topped ones) to prevent them from bottoming out on our studs. These will also fit on longer studs, and studs with un-threaded portions protruding from the hub/flange.
The tapered washers are spares or replacements, and are NOT to be simply put on top of the existing ones already fitted.
I will contact those who wanted a set. For others who are interested, please pm. Postage times from U.K normally range from 1-2 weeks.
PostPosted: Fri May 27, 2016 9:53 pm
Very nice. :)
Don't screw SS nuts on dry or they can pick up, use a little WD40 on em.
Last edited by drmini in aust on Sat May 28, 2016 10:52 am, edited 1 time in total.
PostPosted: Fri May 27, 2016 11:33 pm
What?? I just ordered 8 new regular nuts like last night :( extremely interested in these
PostPosted: Tue Jun 21, 2016 12:11 am
A few people have asked for the nuts only. Price is now $125/set without the washers.
1 set has no-one's name next to it so if you're interested, please pm. Only when there is enough interest to fulfill the minimum quota of 6 sets, will another lot be ordered...
Matt (TheMiniMan)
Blunder
jubblies
MikeJ
Gezo
Lillee
Please see pm.
PostPosted: Fri Jun 24, 2016 9:02 pm
Hi, am I too late to grab a set?
'66 Mk 1 Cooper S,
'69 Mk 2 Cooper S,
'81 Leyland Mini (in New Zealand),
'78 Clubman 'Special' (track car)
PostPosted: Sat Jun 25, 2016 7:30 am
Hi. I am waiting for a reply from someone on the list. If I don't hear from them by the time the nuts arrive, they're yours.
PostPosted: Wed Jun 29, 2016 7:11 pm
Hi, drop me a text - 0418 500205 - if they become available.
'66 Mk 1 Cooper S,
'69 Mk 2 Cooper S,
