It is currently Sat Jun 21, 2025 2:17 pm
 Post subject: Boring an 1100cc engine
PostPosted: Mon May 23, 2016 12:59 pm
Hi Guys,
just wondering if anyone has got an mini engine bored, and if where in victoria?
and how big can i get an 1100cc bored out? worried about the piston walls.
Cheers Alex
PostPosted: Mon May 23, 2016 1:23 pm
68mm.Project 68
Roads need more corners
PostPosted: Mon May 23, 2016 2:24 pm
fuzzy-hair-man wrote:
See details of this on www.russellengineering.com.au
To get out to 68mm (1220cc), it has to be offset bored.
If you fit a 998 crank instead of a 1098, you will get 1108cc. Stronger crank than a 1098 one. 8)
PostPosted: Mon May 23, 2016 3:46 pm
put a location in your profile and someone near you will recommend a place. I can name a bunch, but they might be a long way from you. Any reputable engine reco shop will be able to bore it... but then there is more to it than just running the bore down the block
PostPosted: Tue May 24, 2016 9:17 am
ok thanks i will do it now
PostPosted: Tue May 24, 2016 9:28 pm
ah - Phillip Island - worth giving Toby Tyler a call?
PostPosted: Thu Jul 14, 2016 9:51 am
Mick Tyler here of Mini Spares and Repairs in Seaford. Give us a call, we use a very good engine reconditioner in the next suburb for all our machining, if thats closer enough. Cheers
PostPosted: Sat Jul 16, 2016 12:09 pm
I gave him a bunch of leads via PM back when he posted the above, haven't heard anything since
PostPosted: Fri Aug 12, 2016 1:12 pm
all good, thank you so much guys. will get onto it asap, when i can.
