It is currently Sat Jun 28, 2025 9:51 am
PostPosted: Sat Jun 18, 2005 7:54 pm
On the invoice after having my engine tuned, the mechanis pointed out the following needs attention:
Needs new engine mounts
Gearbox selector mount
SU carb throttle shaft worn
Rack and Pinion tired
exhaust leak at headers
How hard are the enging mounts to replace? The rest I can handle.
Thanks.
PostPosted: Sat Jun 18, 2005 8:49 pm
where was it tuned, if it was at mini bits i reackon they charge way too much!!, engine mounts arent hard to replace, undo one side, jack up the engine replace that side and then re attach the engine to the frame, do the same on the other side, i did this with mine its not difficult :wink:
Potato
PostPosted: Sat Jun 18, 2005 9:26 pm
I didn't go to minibits. I went to a more local engine tuners that does a few classic cars.
Big place. They had it for two days, getting parts overnight for it, and it runs quite well now, idles at 600-1000, as opposed to 1600!
PostPosted: Sat Jun 18, 2005 9:44 pm
yeh what sean said
you should be paying about $7.00 an engine mount, they are different for both sides
(if its a matic, expect to pay $120 for the pair. one hundred and twenty)
Inconspicuously Conspicuous
PostPosted: Sat Jun 18, 2005 10:23 pm
hmmm i could have sworn that my engine mounts looked the same on both sides. :?
its only the rubber/metal bit you replace Duc :?
PostPosted: Sat Jun 18, 2005 10:26 pm
one hole is 7mm off
i picked up the wrong one and was about to drill a hole in it
marcello picked up the other one and said wait a minute
yeh two metal plates sandwiching a rubber slab
$120 for a matic, $15 for a deluxe
mick my friend, supply, demand, rarity.
PostPosted: Sat Jun 18, 2005 11:00 pm
you can also get Engine Mount's with the nut welded on..or your okay at welding you can do it your self :wink: Other wise you may need someone else to hold the other Spanner :?
PostPosted: Sat Jun 18, 2005 11:26 pm
How do you tell if your engine mounts need replacing? I can't move my engine at all, but when idling it shakes quite a bit..
How many engine mounts are there? Theres one at the back isn't there? Is this hard to replace?
Can anyone recommend a place for tuning minis in sydney? Is mini and suzuki at padstow good?
