It is currently Sat Jun 28, 2025 1:46 am
 Post subject: Wireing
PostPosted: Fri Apr 22, 2005 11:56 pm
Who's a good sparkey
I'm presently got my front wiring Loom on the wall and wish to up grade a number of wires Head lights, Alt etc.
What I wish to know is what Gauge of wire is best to use or type, something else.
Yes Reg's are going to be used for Hi work area's and the reason I wish to upgrade these area's.
I will possible contact vinwires but want to know what I want first :wink:
Cheers and Thanks
PostPosted: Wed Apr 27, 2005 7:33 am
Bump...Come on Guys
PostPosted: Wed Apr 27, 2005 7:46 am
I've only ever used a thicker guage on the headligh wiring..but if your going to start from scratch i wouldn't know..
but check here:
http://www.ausmini.com/forums/viewtopic.php?t=6653&postdays=0&postorder=asc&start=0
danidad did respond to you..
PostPosted: Wed Apr 27, 2005 4:38 pm
Cheers Josh...Fun how threads work :wink:
PostPosted: Wed Apr 27, 2005 9:02 pm
haha no probs 8)
PostPosted: Fri Apr 29, 2005 4:56 pm
To answer the original question. The gauge of wire you need to use is 2.5 square millimeter flexible copper.It's rated to at least 20 Amps (One light will use about 8 on it's own). Be sure to ask for flexible though as you may end up with house (commonly known as building ) wire which is not designed for vibrations or flexing. It also has about half the number of copper strands.
I did however purchase a new loom from Classic Looms in Melbourne 8 years ago for 240 dollars. The result was a perfect new loom with the correct colour wrapping (black cotton with a little bit of gold for my app.), upgraded 20 amp lighting circuits and the inclusion of two relays to operate the lights near the fuse box. You can ask for any old inclusions you like. Reversing lights, electric fuel pump, alarm, speaker wires blah blah blah....
well worth it if you have the cash
PostPosted: Fri Apr 29, 2005 5:44 pm
Are new looms generally still available...not that I need one now by loom is royally fooked :(
[Maverick] 1971 Mini K
PostPosted: Fri Apr 29, 2005 5:59 pm
Mick Cheers for the Info as that is the info I have been looking for.
Thier is also Vinwire also...I only intened to replace a number of the wires Eg Lights to a Higher Grade :wink:
PostPosted: Fri Apr 29, 2005 6:25 pm
From memory they only took 3 days to make it and COD'd it through the post.
If you go to an autosparky for the wire, they use a different designation for the wire size. They call it by it's diameter, not the cross section surface area. From memory the equivalent is 2mm but if you say you need 20 amp flexible wire, they'll simply ask what colour you would like.
Mick
PostPosted: Fri Apr 29, 2005 9:19 pm
Be careful if buying wire from Supercheap etc, the Chinese wire is rated by the diameter of the plastic insulation! :shock: :?
eg. their 4.5mm cable is rated at 15 amps...
I like the tinned flexible copper marine grade wire from Bias Boating Warehouse, but it only comes in 2 colours, red & black. :cry:
PostPosted: Fri Apr 29, 2005 9:43 pm
Supercheap won't be getting my $ on this one :lol:
