It is currently Fri Jun 27, 2025 8:44 pm
 Post subject: Alternators
PostPosted: Wed Apr 13, 2005 11:37 am
I am in the process of revisiting the possibility of placing an alternator at the front of the Starlet motor. Now I have sourced a much smaller alternator but obviously I want to know if it will work. The ones I have looked at are all NipponDenso (same as Starlet original item), with the three prong plug with S, IG, L. My questions are:
    how do you know what power output they have?
    Should the pulley diameter be the same?
    Does it matter particularly what car they came off?
 Post subject: Re: Alternators
PostPosted: Wed Apr 13, 2005 3:45 pm
I tink you take it too an auto sparky and they'll test it. You prolly need to take your crank pully too.
PostPosted: Sun Apr 17, 2005 11:19 pm
when you buy alternators the should come with the what amperage and volts they put out, but another way is to check by a multi-meter..
it will be roughly the same..
it probably be best to buy lucas or bosch and yes id think you'd need to buy one off a old mini or any rover mini..
i hope that is a little more helpful..
