It is currently Fri Jun 27, 2025 6:20 am
PostPosted: Sat Mar 26, 2005 5:47 pm
Blew my head gasket already....bit crap.
So...
Im all set to replace it, but I was thinking while its apart what else could i do to increase performance ?
Any ideas people ?
PostPosted: Sat Mar 26, 2005 5:53 pm
when i blew a head gasket i put cooper s double valve springs in also you could put unleaded valve seats in you head and maybe some head work too :wink:
PostPosted: Sat Mar 26, 2005 6:03 pm
I'm assuming it's a small bore block? Were you using a copper gasket? the new ones are NFG...
Go the ACL Gasket, Part #CP250MT. Available from Repco etc.
While the head is off you can do a number of things, port the head, fit double valve springs, bigger inlet valves etc..
Find out what type of head you have too.
PostPosted: Sun Mar 27, 2005 9:07 pm
If it`s not valve bouncing the don`t fit double valve springs,,,the extra load only slows the things down
double valve springs are fitted to a higher reving engine to help stop valve bounce or valve "float",,,that`s all,,,by fitting double valve springs to an "otherwise" STD engine will only slow the engine down
simple as that!!!!!!!!!!!!!!
Maybe fit slightly larger inlet valves & open the holes up to suit,,,& if you want to spend some more money & fit unleaded valve seats then do so too, good for longetivity
PostPosted: Sun Mar 27, 2005 11:09 pm
Whats the average going price for an unleaded conversion ?
PostPosted: Sun Mar 27, 2005 11:13 pm
i cant realy remember but i think it was $150 to fit hardend valve seats
PostPosted: Sun Mar 27, 2005 11:16 pm
Im am under the impression I can replace the head with one that will give me a performance boost ?
Is this correct ? if so, what could I expect to get for say $500 just on the head itself ?
PostPosted: Mon Mar 28, 2005 7:59 am
If you are running a 998 or 1098 you can put a 925 or 940 head... :wink:
940 head is a bit more work on the Block..(Valvue clearance)
if you can find the 925 head you are a lucky man..I'm still looking
PostPosted: Mon Mar 28, 2005 8:15 am
Gaf, you dyslexic are...
it's a 295 head, not 925.. :wink:
PostPosted: Mon Mar 28, 2005 10:35 am
what would the head off a Mk2 Cooper S most likely be ?
PostPosted: Mon Mar 28, 2005 3:38 pm
Im running a 12G202 head
PostPosted: Mon Mar 28, 2005 4:30 pm
I do that all the Time 8)
940 is your best bet..but you will need to pocket the block..so the Valvue's don't hit the block.
202 heads can be opened up better than a 295 by GR in Sydney
Regardings to heads as per factory http://drcwww.kub.nl/~bogaard/heads.htm
PostPosted: Mon Mar 28, 2005 4:32 pm
UPDATE:
Ok, i have to bite the bullet and get a full engine + gearbox reco.
I am after the name + phone numbers of all good mini specialists in Sydney + Newcastle who can do what I am after.
I will remove engine myself + install myself. I am only after reconditioning of engine, and maybe some performance parts.
Any help will be appreciated!!
Thanx people!!
PostPosted: Mon Mar 28, 2005 4:50 pm
GR Greame Russell
113 North Rocks Rd (02) 9630 2195
Mini Classic
2/27 Hope St Ermington (02) 987 47211
Mini Spare Centre
80 Gibson Ave Padston (02) 9774 3388
Karcraft
9 Egerton St Silverwater (02) 97 9944 (for Parts)
PostPosted: Mon Mar 28, 2005 5:01 pm
Thankyou for that, shall give them all a ring 2moro.
Is anyone able to tell me if I will get change out of $2000 for a rebuild of an 1100 engine + gearbox ? Or should I make my budget a tad bigger ?
